cage surface rust
Old Jul 18, 2006 | 04:34 AM
SPOOLINmatt's Avatar
Default cage surface rust
whats the best way to knock off all of the surface rust on a mild steel roll cage. Gotta paint that sucker
Old Jul 18, 2006 | 09:00 AM
dfoxengr's Avatar
Default Re: cage surface rust (SPOOLINmatt)
wire wheel.
Old Jul 18, 2006 | 04:10 PM
jdlracing.com's Avatar
Default Re: cage surface rust (dfoxengr)
I would shy away from a wire wheel unless there is a ton of surface rust. If there is just a light coating of rust, I would get some sandpaper. It will be much faster and come out with a better finish due to it being able to be wrap around the entire tube and give an even finsh also.
Either will work, I just think a wire wheel will leave a rough finish that you will have to sand down later. Use sandpaper, do it once and do it right.
Turbo Josh
Old Jul 18, 2006 | 04:21 PM
Default Re: cage surface rust (jdlperformance)
i was thinking the same thing. its not bad yet and i should be getting started on it this weekend after certification. Gotta get a good primer on it soon. Im going to paint it to match the exterior color.
Old Jul 18, 2006 | 04:24 PM
dfoxengr's Avatar
all wire wheels ive ever used leave it shiny, lol.
Old Jul 18, 2006 | 04:30 PM
dkim48's Avatar
go to any paint store...they should have different types of scotch brite pads. the red color one would work well for light surface rust. good luck
thecruzs2007@yahoo.com
Nov 13, 2010 05:48 PM
JDM JEFFREY
Paint and Body
10
Dec 12, 2009 02:13 PM
Angry Moose
Paint and Body
Oct 23, 2007 07:10 AM
professorman
Welding / Fabrication
12
Nov 6, 2006 06:26 PM
ckkl
Mar 10, 2003 07:47 AM
