Machine shops in the tri-state???
Old Aug 1, 2006 | 05:50 PM
5.0killa's Avatar
Default Machine shops in the tri-state???
I need to get head bolt threads repaired and im looking for a machine shop that uses time-serts in the tri-state area.
Old Aug 1, 2006 | 06:23 PM
KFMRC's Avatar
Default Re: Machine shops in the tri-state??? (5.0killa)
Depending on the block you may not want to use them. Why don't you want to use heli coils. The size of the inserts requires a miuch larger thread to install and the block gets thin. Use heli coils with extra long inserts not the standard length. the other option is to use oversize studs if there is something available for the block your using.
Old Aug 1, 2006 | 06:43 PM
5.0killa's Avatar
Default Re: Machine shops in the tri-state??? (KFMRC)
I just want something that i wont have to worry about. Its a turbo motor so its going to be abused
PissedoffHONDA
May 23, 2008 08:21 AM
Fezzie
Jan 5, 2007 07:03 PM
92gsrhatch
Jan 22, 2005 09:50 AM
SOUNDEFFECTS
Nov 26, 2002 07:23 AM
T4sol
May 21, 2002 08:07 AM
