FIRST TIG project
Old Aug 19, 2006 | 07:16 PM
99_GS-T's Avatar
Default FIRST TIG project
It's for a 1G FWD DSM. I've done a lot of tubing fitment before and built some exhaust manifolds, but they have always been with a MIG setup. I bought a Thermal Arc 185 TSW a couple months back and this is the first real project I've taken on with it. My camera doesn't take the best up close pictures, so I only have 2 pictures showing the welds.
3" downpipe/O2 housing
3" Cat-back It has to go around a gas tank and over the axle, but I managed to cut out about 90 degrees worth of bends by getting a little creative with the path of the tubing.
Any suggestions or constructive criticism would be greatly appreciated.
Thanks
Old Aug 19, 2006 | 08:07 PM
Mr. B18's Avatar
Default Re: FIRST TIG project (99_GS-T)
Look great! The fitting is perfect.
Old Aug 19, 2006 | 10:49 PM
F20Cteg's Avatar
Default Re: FIRST TIG project (Mr. B18)
Nice! Good Job!
Old Aug 20, 2006 | 02:09 AM
Jason-'s Avatar
Good job man! I like the looks of it.
Question.. how much was your Mig?
-Jason
Old Aug 20, 2006 | 05:51 AM
SL0WEGG's Avatar
Default Re: (Jason-)
just an fyi it was tig'd not migged. looks good!
Old Aug 20, 2006 | 06:33 AM
RC000E's Avatar
Default Re: (boostedej1)
Man......damn it.....that's nice but....I don't know if I should say.
How about this...can you take a picture of the car from the passenger side so I can see the exhaust from that angle?
Old Aug 20, 2006 | 10:16 AM
Jason-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">just an fyi it was tig'd not migged. looks good! </TD></TR></TABLE>
Yah, I realized that after I hit post and then I fell asleep.
-Jason
Old Aug 20, 2006 | 01:57 PM
99_GS-T's Avatar
I've got a question I hope somebody can answer for me. When I fit the tubes together, I can get the tubes to fity perfectly together before the weld. As I weld, I can watch the tubes expand at slightly different rates. This makes the seam uneven, as can be seen in the second and third pictures.
What's the best way to prevent this from happening?
Old Aug 20, 2006 | 02:06 PM
nowtype's Avatar
Default Re: (99_GS-T)
Lots of tack welds or slip fitting the joints.
Old Aug 20, 2006 | 05:45 PM
F20Cteg's Avatar
Default Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">Lots of tack welds or slip fitting the joints.</TD></TR></TABLE>
You don't need lots of tack welds. Just 3 or 4 will do it. Also when you weld get into the habit of crisscrossing your welds, ie a quarter here, then opposite side do another quarter, etc, until the pipe is welded all the way around. This prevents the pipe from expanding on one side.
&gt;&gt;&gt;&lt;&lt;&lt;
Old Aug 21, 2006 | 10:30 AM
99_GS-T's Avatar
F20Cteg, I'll give it a shot. I didn't do it that way because it would cause a lot of start and stop points. But my welds aren't that pretty, so I guess it's not that big of a deal.
Also, am I getting the uneven expansion because I'm not controlling the heat correctly? Or is this to be expeted when welding a bend onto a straight tube simply because of the difference in the metal thickness between the inside and outside radius portions of the tube?
Old Aug 21, 2006 | 10:44 AM
RC000E's Avatar
This is where a pulser control can help out alot. You can put alot less heat into the weld and the surrounding metal using it.
Old Aug 22, 2006 | 12:10 AM
F20Cteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">F20Cteg, I'll give it a shot. I didn't do it that way because it would cause a lot of start and stop points. But my welds aren't that pretty, so I guess it's not that big of a deal.
The idea would be to go over the spot welds. That way they won't show.
All materials will expand when heat is applied. SS unfortunately expands more than mild steel. Keep the heat down enough but not enough that the metal is not penetrating.
O16581724 5 2 5
Oct 21, 2005 11:37 AM
Sprockets
May 1, 2005 01:32 PM
X-cement-filled-EG-X
13
Mar 21, 2004 08:05 PM
ScrapinSi
Sep 24, 2003 04:19 PM
