- F22 crank on K24 (Destroked 2.2L for 10000 RPM)
- 2009 tsx engine swap?
- K20z3 to a K24A tsx swap
- Best K24 longblock?
- k24a and k24a2 camshaft interchangeability
- How practical is “converting” a K20A3 to a desirable K20?
- AEM K-Series Fuel Rail 25-111BK
- K24A1 Cam tower compatible with K20A3
- K20A Injector Length
- Head gasket size for sleeved block
- K-Series Water lines for turbo cooling
- 04 Accord 5 speed wont shift into gears!
- K20 issues starting (cranking)
- iAt sensor
- New owner of a K20..need advice on what to do next
- Tsx pistons worth it?
- Does anyone have a resonator?!?!
- VTC actuator position for timing chain replacement on 2003 Accord K24
- Need new radiator.. get one with a fan???
- A/C Delete on 8th gen SI
- 3 inch to 2.5 inch exhaust - causing problems!
- k20 Pressure washed motor... now so spark
- Questions about k20a2/k24
- Help a Newbie understand the K-series please
- K24a wiring help!!
- HELP NEEDED!!!!! K-SWAP CRX
- adjustable fpr for returnless system on tsx?
- What Kpro should I be looking at for K20A2 swap?
- 7th gen accord k24a8 with k20z3 head swap help!
- k20a2 Timing chain/VTC gear issue.
- Help! cluster not working after doing a k swap into 99ek
- Stock k20a2 inlet with centre feed tb
- mr2 electric ps pump in tsx?
- Wtb k20 eg motor mounts
- Transmission
- new to k world. best boltons combo
- EG K swap no-start.
- Honda K20 A
- Honda K20 A
- K25 Engine Compression Limits on E85
- HUGE compression loss after Spinrgs+retainer install k20a2.
- Cl7 EuroR eg swap wiring help!
- K20A eg swap questions
- 2006 CR-V K24A1 trans??
- Flash pro won't connect to ecu
- To build or buy a JDM K20 (1979 Mini Cooper Swap)
- Serpentine Belt comes off while driving.
- 06-08 k24a2 vs JDM k24a
- k20z3
- K20 Rocker Arm Issue?
- Could I use a K20Z1(06 RSX TYPE S) engine harness on a K20A3 Engine (EP3)???
- K24a2 with innovative k20 lean mounts???
- Ktuned electric water pump, plumbing Q's k20a2.
- Under car lean mount header options?
- EG K20RSwap costs? vs a H2b swap.
- 03 Accord k24a4 cranks but no spark to injectors (noid light tested) I need my car
- Difference between a 5 speed and a 6 speed k series clutch
- Head Heater port/hardline plug for k20a2.
- K24A3 Engine check unknown code
- Wiring fuel pump relay with ktuned conversion harness.
- Vtec not engaging
- Help deciding what TPS to use. HALL effect vs reg.
- K20a3 rebuild
- What is this port on the water pump, can i block it?.
- question regarding similarities in k24a2 and jdm k24a
- K20 integra problems with cold start
- Hey Did A KSwap in my rsx need help
- Questions about the K series
- K24Z7 Civic supercharger on K24Z3 Accord?
- tensioner piston sucks it's self in when valves close. skips 4-6 teeth!
- k20a2 Supertech DVS+retainers install question.
- K swap 1988 Pontiac Fiero GT
- k24 HELP !! VTEC actvator or ECU Problem ?
- k24a4 tranny in k20/24 all motor build
- who has the best $1800 CNC ported head
- Em2 k swapped header fit a ep3
- Motor Mount for SK2 Alpha Header
- k23A1 swap
- 7gen type R vs Si
- Can I put a k24 head on a k20a3 block if so what would I need
- K20z3 EP3
- K20z3 EP3
- honda civic DX 1998 usa version
- What Computer Brand To Use
- K20 fitted at an angle
- Auto to manual Acura RSX
- 2005 ep3 k20a2 full swap
- Wiseco pistons in Washington, D.C. Area
- Rebuilding K24A1 w/ A2 Rods - New rod bolts or are old ones fine?
- HMotors K20 into an EG Parts List
- K24a2 Pistons Question
- K24 Del Sol Project
- Valve springs.
- Kswap need some help/info
- K Series Limit
- K swap starts then dies
- 2008 Element K24a8 ECU questions
- Gen2 CR-V with a K24A1- what are my AFFORDABLE upgrade/swap options?
- Info about the K24A4 .. Automatic
- K24 CB7
- Intermittent Fuel Cut / Misfires and CEL
- k20a2 with spun rod bearing
- K Series all motor HP potential, $$$, and which setup/ why??
- Best K series head/block combo for boost
- K20 CRV intake manifold swap options
- K24 P0328 code and steering wheel buttons not working
- 6266 Turbo on Honda EG
- 4 Piston is giving away a motor
- Hondata exchanged by Doctronic experiences
- Can I use RL-5 Rods on K24A1 pistons and block?
- suggestions?
- K20A4 (CRV SAE)
- K20Swap on Civic Ej1 - Electrical questions
- 98 Honda Civic HX engine swap conversions wanted
- Ignition coil 30520-pna-007
- JDM k24a questions
- K20A3 With K20A2 Internals ?
- Intermittent smoke from exhaust at random times?
- Wideband X narrowband problem.
- k24a2 in a 02 accord build idea
- K20A2 EP3 spark miss
- Post Your Skunk 2 Ultra Manifold!
- k20 removal
- which K20A motor for EK
- Ep3 k20a3/k24a2
- What ecu to buy for 02 rsx type s
- 06 typeS full ITR swap help.
- 205/50/16?
- K24A1 cam wear
- K20z3 Swap into 02 RSX
- Oil consumption
- K Series Complaint
- K24a4 Air/Fuel Calculations and Info
- K24z3 block k20a3 head?
- 92-95 EG Fuel Feed Line
- K20 engine number??
- Looking to buy a k24a1 eninge for my CRV *Cr-V
- K20 TWM itbs on a Z3 head clearances?
- 06+ k24a2 with K20 vts
- Skunk2 DIC
- How do I fix this?
- K swap dc2 with power steering drive belt lenght?
- EG bubble w K20a3 in it
- K series swap help?
- Grams injector issue
- Fully built k series
- extra k24
- K24a4 head w/ k24z7 bottom end
- tensioner reset
- Storing k24a2 long term
- Quick question about AWD conversion.
- EP3 or RSX radiator into K swapped DC2-R
- K24W1 Turbo/supercharger?
- k20A3 head quetions
- K24A2 Turbocharge build
- Looking to build a racer
- K20 turbo eg build
- Swap K24a4 for K24a
- k24/20 AWD Integra Build(slow)
- K series or B series
- FD2R k20 into an eg
- Password on KPro
- K swap no start?.
- Integra k swap awd
- K24A2 Cam into K24A1
- EG KANJO K20
- k20 help!
- DBW throttle body shaft removal?
- .010 oversize Pistons with standard rings
- Which flywheel cover (bottom trans brace/plate) to use?
- k24z7 Swap in ej8
- K20a3 build
- Are you happy with your k swap? Reviews & Impressions?
- I need help lol
- k swapped miata
- XTD CLUTCH KIT ON RSX HELP
- k24/20 build help
- Best Cold Air Intake For DD
- Does k24 have timing chain tensioner issues like K20 had?
- K20a2 more power
- k20a3 a2 tranny hybrid
- !!Help me identify O2 Sensor!!
- Kswaped EK question on turbo cooling
- K24Z6 block with K24Z7 head
- Fuel pump not priming...
- 12s on k series
- !!K-Tuned A/C and P/S Eliminator Kit issues!!
- Someone PLEASE HELP!!!
- Anyone have pic of K20 valve cover baffle removed?
- Gasket K24Z3 + K24A2
- K24 swap.
- Acuity Hall Effect TPS
- pilot bushing/ bearing/ (metal ring)
- Cams for my k20a2 thoughts?
- cams choice on itr k20a
- k20a3 removal of rocker shafts/cam stacks
- K20 Auto-Tensioner bolt is STRIPPED !
- K24a2 into rsx vacuum lines
- 02 Civic Ep3 handbrake dash light stays on
- 2002 ep3 having problem starting when car is cold HELP
- 96 hatchback Kswapped randomly shut down and will not start
- oem k series injector differences.....
- RSX trouble starting
- which throttle body for RBC IM?
- 05 ep3 no power
- 2004 crv lx with 4wd
- Trying to get more power
- 2007 Honda Accord engine swap - to do or not to do?
- Looking to swap an EM1 with K series
- k24z3 TSX motor into DC5 parts, install~!!
- How to install Bee-R on K20A2 Ep3
- Looking for some guidance for a k series build K24A8
- EJ k20a2 dies after pressing throttle ?
- EJ k20a2 dies aftter pressing throttle ?
- 2008 K20Z3 in 2002 EP3 with stock ECU.
- Can anyone help ID these Pistons and rods
- K20 Swap Intera LS
- Help
- K20z1 n/a questions and help
- em2 k24 PRC ecu no spark and injectors are not firing
- k-series engine questions help
- Please help if you can. KA24 only runs when an obd2 scanner of any kind is plugged in
- What do I need for k24 swap on my 1990 Honda Civic Hatchback
- K24a4 Piston rings without removing engine
- Hux Racing K-swap Mr2 +budget vtec setup
- Nitrous K20
- 07 fa5 please help
- Engine Managment/Hondata/ECU Questions
- k24a2 all motor build
- Really stupid clutch question
- K24a?
- 96 hatchback Possible Ignition Switch issue?
- Which is better h2b h23a blue top b16 trannys or k24a4 5 spd tranny on eg hatch vx??
- k20a2 oil pump on stock k24a4
- recommendations for a reputable shop to build my 6 speed trans?
- kraftwerk supercharger k20 swap with ac
- so i need opinions.
- Replacing Valve Seals on K24A1 in 2003 CRV
- kpro for k20a2 94 ej ?
- k24a1 flywheel and clutch interchangeable with other K motors?
- K20a type-s or type-r?
- Kswap parts list EG/EK
- 97 civic kswap will not start please help!!!
- K20 em1 need help!
- NSN4 Transmission shift fork broke
- Fenders
- K20a2 turbo
- Ek k20a3 p1166
- cam command issue please help
