View Full Version : K Series
- Kswap CRX HELP!
- K24A1 head swap
- K-serie throttle body gasket question
- Skunk2 Alpha Big Bore Throttle Body ANTI-STICK Recipe/How-To
- k swap problems
- K24z7 dropped bolt
- K24A 1996 EK Civic Crank No Start -ECU KPro 4 Not Grounded? ADVICE NEEDED
- I have a crank no start
- Z3 trans Vss vs Css
- Will a stock tsx ecu run a k24a2 with a 50 degree vtc
- P0336 “CRK sensor intermittent interruption” code
- K24Z3 swap in an 06 CRV (K24A1)
- K24 RBB3 weird idle
- K20 Swap- Possible Bad ECU
- K20a2 engine refresh and preventative Maintance ?
- 00 Civic swap axles/halfshaft+ecu
- 99 Civic Si k24a4 Swap Help
- tune help
- Running rich and Rev hang when jabbing throttle
- K24 built for ultimate reliability
- Rocker arm assembly removal
- What parts are useful from an integra for k swap in an EK
- Help with VTC Gears for K24a2 08
- limited boost and vtec not engaging. help?
- K Swap Wiring Questions
- K20 ep3 bad dyno numbers
- 93 Integra turbo K24a2
- K series trans need help
- K24a with k20z3 trans need help with what 36mm axles and halfshaft
- k20a3 netrual redline
- Oil Cooler ideas
- AC delete but keep PS
- Helping a Friend Blueprint His N/A K24A2 Build
- Planning to K24 swap my Civic EX EJ1. What is everything I need?
- Best lube for starter planetary gears?
- stock ECU question K24 into Ford
- What is the best K24 to swap to
- Got a 09 accord with k24z3 and a ek looking for advice!
- K20z4 swap with DBW
- EP3 Harness & FA5(PNN3) Trans. How to make speed sensor work??
- Bad tensioner or sign of larger issue
- Please Help! My EP3 won't fire
- Help for gearbox turbo k
- K24 swap question
- The unwanted engine.
- K24 Build Questions
- Can you help solve this awkward revving problem
- Help with a hesitation problem
- Best way to clean kseries
- Cold start rattle
- What lines can be deleted?
- 2004 accord
- Starts when cold but only cranks when hot
- Intake manifold choices
- 2004 CRV LEAKING OIL THROUGH RINGS
- K24a1 bottom / k24a2 head
- 2002 K24 Oil Filter Holder
- K24 in 8th Si. Do I have the wrong K Tuner? Missing something simple?
- K20A economy plans
- 06 civic si crank, no start
- K20A RG Stepwgn
- K24a2 Ek with rsx base
- K Series 6-Speed Automatic Transmission Options
- 2004 CRV, K24A1
- NO INJECTOR PULSE
- k24a2 build questions
- ECU not storing readiness monitors status
- Transmission question
- Please help me
- K swap 99 hatch HELP pls
- 1978 Honda Accord
- No Fuel Pump Wont Crank
- K24 Engine code....JDM v USM
- Deck height question.
- VTEC Intake cam on exhaust side
- k20C engine identification
- Vertical line and cylinder three ?
- K20a2 terrible performance
- DAMAGED CAMSHAFT HELP
- 2009 honda accord
- Iacv on k20/24 frankenstein
- 2018 Civic Ex 2.0L K20C2 6 Hose Leak Help
- Kswap ECU problem
- Auto to manual conversion
- what k series do i get
- MAPS Issue with K-swap: Constant -13.5psi signal
- K24: After Replacing the timing Chain Tensioner, Chained slipped very bad
- Advice/encouragement needed. Dropped a valve feeler gauge when doing valve adjustment
- EG Subframe in EK for K24A2
- Jdm k20a into ep3 si
- Rebuilt transmission making clunking noise
- Will K20 Turbo Kits fit K24?
- K20a2 startup noise, sounds like metal on metal
- blowing past 2step @ 100% throttle
- What gearbox or gear set should i get for k24 600whp-650whp
- 2004 Accord lx coupe Clicking inside the trans close to diff
- Kswap overheating.
- Buying a kswapped car with ktuner
- SWAPPING MY D16Y7 ENGINE FOR A K-SERIES
- k20z2 engine
- Qustions about upgrading my k24a1
- 08 civic si turbo
- My first k20a2 swap into ej9 need help
- Eg hatch k24 swap
- K24 build question
- K24z3 VTC solenoid PWM frequency
- 03-07 Honda accord k24 in a 05 CRV?
- K20 Building motor Question about best internals for my application
- K20z3 overheating
- K24
- K24z3 crank pulley timing marks
- Kswap standalone custom chassis in denver
- Shifter cable routing EG/DC2
- Issues with vtec
- Fuel system upgrade
- K24 With K20 Transmission and clutch
- k24a2 with element /crv ecu
- K24 CRX
- Vtec solenoid VS vvt solenoid. k20a3
- JDM K24A OEM Exhaust Collector Flange Available?
- Hondata Kpro V4 On Line Ignition Off
- Info on a D to a K20A2 in a 6th gen 98 civic ex coupe
- jdm k24 pulley vs USDM k24 pulley
- Losing spark after two or three fires
- What Clutch Kit to use on my JDM K20A?
- JDM K24A Engine type ?? RAA-2 head RAA Bottom end RBB CAMGEARS AND CAMSHAFTS
- 2003 RSX K20A3 TO K20A SWAP ECU
- Help with a base map
- Where’s my oil leaking from?
- Jdm K20a swap identification?
- Ep3 k20a swap
- this girl in the gym *damn*
- k swap integra doesnt engage
- 2014 Accord 2.4L cam timing off po341
- Help with my JDM k24a misfire
- Any EG crossmember for K and AWD swap?
- Bmw E30 K swap advice needed
- 07 Accord LX - throttle body pigtail cables came out !
- K20z3 in a 99 civic. Fuel pump no prime
- Em1 intake question
- Cluster Temp Gauge
- K23 Head and Turbo
- K20A2 tranny bolt pattern/fitment and compatibility
- Tuner needed in SLC area
- No oil pressure while cranking?!?!
- K24 Valve Adjustment
- Transmission SEALS
- Where/how to get a k20 without spending 4000+
- Rsx type s K24a2 swap feedback-Thoughts
- k20 vs k24 mpg
- K20C1 Head swap
- 01 prelude with k24 easy questions
- K24A2 swap in a 1997 civic dx
- Another kswap jerkin' around
- Dc1 kswap
- 2007 honda accord k series compatibility
- K24Z3 into 96 Honda Civic EX (EK Chassis)
- K24 civic starter fire
- K-Swap ECU Pinouts/Diagrams,Harness
- H2k intake using H22
- gear ratios and tire sizes
- K24Z1 Block Build. Worth Using?
- K20z3 Internals in a 05 Element AWD 5 Speed
- Frustrated 2003 Accord not starting.
- 2012 Civic Si Top Alternator bolt broke, HELP PLZ
- Turbo-level blow-by from na K24 oil fill hole?
- type S oil pump on K20z3
- 2008 accord K24 crank won't rotate 360!
- K24/K20 frank build questions
- K24 swap no crank no start
- HELP!! Car jerks in vtec and doesn’t go
- Problems - Valve and Timing Inspection @ 170k
- I have a celica 7th gen. And was wondering about some things with the k series engine
- K tuned thottle return spring too STIFF
- EG6 with K2a in progress... catback exhaust question.
- K24z7 problem with the oil pump chain
- I Hope My K Series....
- K24 throttle body vacuum lines
- Best K engine for boost
- NO PRIME SOUND WHEN KEY ON, BUT CAR STARTS UP!
- K24z2 block with k24z3 head
- Normal ECT?
- Cooling issue
- 96-98 dash conversion harness for a 99-00 ek k swap
- looking Shop in central CA for a K24 swap
- Honda Stream k20a2 swap
- Help with a New Dream Project (K swap Turbo EK Hatch)
- Ek coupe k20 swap
- es9 civic
- Removing vtc actuator bolt
- eg k swap vtec not working plz help
- engine swap england build 06 CR-V
- Crank tdc marks aren’t Lined up with real tdc
- K20a2 skunk2 Drop in cams
- K24A8 Mods
- 07 CRV Misfire JDM swap
- Am I wasting my time looking into turbo-ing my k24a8 accord?
- 510hp K24 turbo swap S13 240SX burnout (video)
- K24A4 VTEC Killer
- JEGS K20a2 Crate Engine?
- Engine Axle compatibility?
- Camshaft locking tool
- 2002 CR-V issues with the K24a1 Engine
- K20a swap in my 05 civic si hatch
- k24 swap eg, getting electrical feedback noise after swap
- Help me with my tapping issue
- K24a1 timing chain, do it or save my money?
- K24 differences in Air Assist Control Solenoid Valves-WHY?
- 2004 accord poor gas mileage??
- DEBATE, What does VTEC pressure switch actualy do?
- K Swap EK K24A2 KPRO V4
- K series for dummies
- Bump in power after VTEC disengages
- K swap
- Intake Mani coolant passage delete
- TSX Engine in subaru outback
- DBW throttle for a PRB manifold
- Oil Level/Capacity
- VTEC Solenoid
- K20A3-Electrical Wire Connector Types
- K20A3 SWAP EK TUNING QUESTION
- Why can't I put my 2001 prelude T/O on my 2002 rsx type s???
- Looking to clarify few ECU pins - charging system? what kind of IAC?
- K24 swapping 350z
- K20a dc5 Type R in eg halfshaft
- 1999 civic K swap
- 05 up k24 swap into dc4 help
- Does it need to be 02-04 k24?
- Fuel Rail Spacers
- Lotus 7 with a K24
- Rotary Valve Assembly-Fitment Problem
- K24a1 vs k24a4
- K20z3/k24a4 swap into a 96 del sol with ac/ps
- K24a4 with k20z3 head
- k24a2 engine purchase
- Need help rwc cam gear
- EP3 Lower compression on one cylinder
- k20z2 actual vtec conversion
- Changed FPR and now misfires and runs rough
- KSWAP EK DC/EG SUBFRAME BOLT SIZE
- K20A3 BASE RSX AXLES QUESTION
- Want to run 103mm crank - welded OEM ok to 11k rpm?
- Need some help with my transmission
- Water Pump Housing JDM K24a
- Need Advice on K Series Prices
- What do I need to put a k20a2 on a k20a3 block?
- Opened an EP3 tranny. Can you tell me if it's good?
- K series Half shaft (intermediate shaft)
- JDM k20a questions
- Em1 vs ej9
