View Full Version : K Series
- Best rwd platform for na k24 build
- P1166 code 91 Si K20a2
- Help with Open budget K Series build
- Breather and Catch Can setup
- Base 270 injectors in Type S?
- bigger tb on stock intake manifold?
- Best Race Header for the price ?
- em1 k20a2 swap
- K20A vs K20Z1?
- k20a3 build
- MAP sensor dosent read
- k24a1 with a k20a2 head ...
- FNWERKZ Performance - K20 K20Z3 K20A2 head on a K24Z7 block
- Newbie questions on Repin 02-04 harness for 05-06 ECU
- k20/k24 all motor help RELIABLE!
- Modifications For 2008 FD2-Type R (Japan Spec) STREET USE only
- Speed sensor in 5-speed to 6-speed swap??
- Enthusiast questions about the k24
- K20A3 w/TSX head or Complete K24A2 '06
- 02 RSX Type S, is a JDM a direct bolt in/turn key engine
- Different kinds of OEM exhaust cam gears
- Will this K20a fit in my car?
- honda element with mil problems
- K-Series Project
- 09 turbo si smoke problen
- K - Sereies project
- K20/K24 swap questions?
- Cam shaft position sensor CRV
- 2005 CRV K24A Engine AT Mods
- 2009 accord k24 i4, dealer said timing skipped a tooth
- k-pro problem, no start
- This is my first post. i dont know where to put this for sale. k20z1
- K20a3 rebuild questions
- Trackforged K20/K24 EG N/A build
- Worth it to fab header?
- 2003 RSX type-S Engine Help!!!
- K-Series Injector help
- k20 da running help
- Prayoonto Racing 2.6L NA Results
- what transmission is better to a k24 engine?
- K20A3 EK 1/4 mile times! with type s ECU???
- Stock Cam Gears on Drag Cartel (DIC)
- Stock K24a2 or stock K20a2 in EP3
- what can i do
- What K24 is better?
- Euro CL9 K24 Dyno Inside
- vss issue
- Axel problem
- More boost on the stock K20: 697whp is close enough, right?
- K20A3 Starting Problems HELP!!!
- Will a d16y7 tranny bolt up to a 03 k series block?
- k20a2 swap - power issues
- Wiring switch panel help please
- help needed: b series tb on rbc manifold and other rbc tb questions
- WHAT IS THIS MANIFOLD
- Camber Bolt question
- Which model for K-build ???
- List of real Vtec K20 ? How to know ?
- K20/K24 Start Issues
- Tech question k20
- Integra K20 Swap, the right ecu ?
- Cam Angle stuck at negative
- k20a2 swap problems (EK)
- Nos??? Is it harmful to a motor ( track purpose )
- HEADER K-TUNED RAM STYLE RACE
- Swapped VTC - Chain Sliped - Fixed it, does this look ok ?
- K SERIES SWAP INTO MY CIVIC
- 1995 k swap eg trouble
- Built motor plugs
- is this an (stock) DC5 valvetrain??
- k20 swap to a 95 Civic Hatch
- k24 drop in pistons
- Toda Racing K20 Header in EM2
- too good to be true k20a3 for 100$
- k20a3 on craigslist
- k20/k24 S2000
- K20A Service Manual
- K24a4 rod question
- K24 in ek
- Kelford vs. Drag Cartel CIC (K20A2)
- 301whp-209wtq KMOD Performance stg.3 K20/K24 87.5x99
- K20/K24 Build Thread (1st build)
- 2nd order harmonic intake manifolds
- Do do I check my CEL - K20 Integra Type R
- AMMFAB ported rbc intake manifold
- K24a2 swap questions
- anyone out theyre using plm megaphone header??
- k24a4 vtec killer piston options?
- Crover1 vs. K20A (JDM) in K20A2??
- Ep3 k20: Advice on CAI
- K swap Questions
- K20 setup intake manifold - RSP, RRC or?
- 92 civic hb k-swap questions
- First build HELPP!!
- k24 stock crack vs bc k24 102mm stroker
- ef9 Si k20z3 starting issue
- longtube header k24/20???
- problems with ek/k24a2 fuel system
- everybody loves k series (unless you go through what i do)
- K20 complete for swap?
- Identifying a K motor by color
- k series into ek hatch
- TB & Intake Manifold question
- K20 awd eg hatch help (trailing arms)
- K Swapped EM1: CA B.A.R. certify?
- Has anyone ever swapped the three popular vtec heads to see exactly hp differences?
- 01 05 civic coupe k20a swap
- k20a awd eg hatch help
- K20 BC stage 2 cams
- testing omnipower tps with issues
- 92_95 civic hatch K20 awd
- K20a2 swap into 94 civic dx...help
- Any one have pics of their K series swap in a EK. Thread maybe?
- K series swap?
- Next to no torque...?
- 93 civic sedan k swap help plz
- K24a1 97EK Harness question.
- INFO NEEDED ON JDM DC5 K20A AUTO SWAP IN EJ6
- kswap axels
- K24A2 oil pump timing procedure???
- ssr header?
- speedometer no working
- need help finding some rings
- K24z3 in 95 coupe
- Dakota Digital with 05+ tranny + harness, 02-04 KPRO
- k20a2 motor tranny same as k20a ?
- cam and camshafts? noob question...
- K20a3 swap into 00 Civic Cx *Intake* *Header?* *SRS?* *FPR*
- K20z3 clutch question
- K24Z3 TSX BLOCK + K20 HEAD??
- Did i downgrade?? eg-K vs eg-B
- K20z3 ecu & harness
- another k question's need link and clear up
- lmk wat i need to finish my k swap!
- k20/k24 setup eristic gasket kit?
- How reliable is K20/K24?
- Motivation....... Drag videos EG Civic w/K20A2 swap
- i have a k24a motor from a 2004 honda accord can i use RSX mounts,brakets, wire harne
- Help with my K20 budget swap in EK
- casting mark or crack?
- Hybrid Racing Essentials Package Review
- My k24 k20 drag crx project and all motor nitrous eg
- 90.5mm k24 potential???
- K20z1 in 93 eg coupe
- K Series Cam Degree
- K20A3 cams how to??
- Dyno and Tune Up for K20 Z1
- Quick Cap on my k20/ek build and Ill post as I progress
- nub
- wanting to k swap my rex
- vibrant catalytic converter
- Real world K swap cost?
- DC2R with K20a + JAP ECU (AUSTRALIA)
- switching camshafts
- eg k20 swap problems
- k20 start up problem
- K20 EK first start header is glowing RED! Help
- How to identify rcrew cams/springs/retainers
- K20A2 surging idle problem
- 03 si with ka24a2, kpro help
- car only going past 3000 rpm's
- K20a, how do I know it is the Type R?
- Biggest problem with doing a k20 swap
- Mi k24a3 en un DC2 desde Espaņa
- Low dyno #'s, k24/k20 mild build
- Is my head salvageable
- k24z3 Question
- ITR intake vs Skunk2 Proseries
- Humble Performance All-Motor Past to Present / 9's Coming Soon !
- K24a plus slicks
- S2000 Oil Pump.
- Looking for opinions
- is it possible to do math to find out if would have clearance in cam k20 w/thin HG
- O2 Sensor Problem (Any assistance will be much appreciated)
- Best K Series Cam Question
- Maybe third time's a charm
- K-noob!
- need chase bays wiring help for EM1
- k24a2 Build questions
- H2B KITS HELP
- K24a2 problem
- K20 question
- K24a2 engine for sale!!
- k20a3 swap into hatch
- will a tsx SRI fit a 2012 civic si?
- K series header question
- K DYNO INFO
- Not sure if I can post this ??
- best k series block to use for all motor need help!
- K20a1 ????
- k20z1/k20a4
- k build
- Drop in cams
- some K love....
- k20a2 can i run aftermarket cams if i have high comp headgasket?
- k20R camshaft question
- any suggestion catback 3''
- RSX ECT Sensor: What resistance?
- 97 acura cl kswap???
- Taking apart K20a2 motor
- 05DC5S 290whp Build Thread
- K-swap?
- K20A2 swap in X1/9: Help me get it running right!
- k24a2 bolt on with e85 dyno
- K20A2 Upgrades
- K head porting.....
- HUMBLE PERFORMANCE MOVING ON UP !!!
- K20A Euro R Tsx Swap in EJ8 with Hybrid Racing Mounts
- K20a2 Rcrew cam injector help!! Please
- K24/K20 Dyno Results - 287whp / 210tq
- *ATTN* Neep a K-pro tuner!
- k20a block what head i use 2 options
- civic k24 no start
- Is the K24Z3 (same as K24Z7 2012 Civic Si) a good engine to modify?
- k20A2 torque tighteen
- k24a2 vs k20a2
- FD2 Cams - Specs?
- Stock AF reading...
- 1999 em1 kswap question
- JDM k20a most power stock block?
- k24a2 CEL/ECU problem
- Stumped on wut happened to my k
- what did you brake first since your swap
- exedy hypercarbon clutches any good?
- axle question da k swap
- What throttle cable with Skunk2 IM/TB?
- k23a1 Q's
- SPEEDDPROSHOP 352 WHP All Motor K-series
- R Crew Harness Instructions for K series in EG
- ANYBODY FROM STOCKTON, CA WIT A K SWAP
- K into EF wants to be "BAR" legal
- Prototype Manifold Testing...AGAIN!!!(9.0)
- KMOD RSX 2011 285whp K24a1 Build-Pics Inside
- how do I identify a good k20 head?
- Engine choice for eg hatch
- Just got a K... Where do i start?
- Looking to go k series in my rhd ek2
- I have a TSX Motor and a spare Type S K20A2 Head (Is it worth the head swap or not??)
- k20/24 parts list. capable 300hp?
- .: My K Build : Custom CNC Head, Camshafts, Crank, Gear Set, Etc :.
- k20/24 build in progress
- Blox type C Cams
- Help with k24a4
- Torque v. Horsepower
- K24a4 Block / K20z3 Head, piston and rod question
- K24 rod bearing question
- Motor mounts
- K24a2 Questions!!!
- I'm working K20/K24 - What can u suggest better - over 8k$ budget
- k20z1 swap in my ek help!!!
