How practical is “converting” a K20A3 to a desirable K20?
I am thinking about K swapping my ES1 Civic, but I can’t afford a K20Z1, K20Z3, K20A2, or any other “desirable” K20 right now. My question is if I swap to a K20A3 now, how hard would converting it to a better K20 be later, or would I be better saving up for a good K20? If I just swap the head, intake manifold and exhaust, I wouldn’t have the 11:1 compression, but would I have all the other benefits, including the power. Right? Are the ECUs and wiring harnesses different? Thanks.
Re: How practical is “converting” a K20A3 to a desirable K20?
Also, I forgot to mention that the price of the engines are not a concern, but availability is. I also need the engine to be a 2005 so I can legally put it in my car. All the u pull it junkyards around me charge a flat rate price of between $175 and $225 depending on the junkyard for all 4 cylinder engines, so the price of the engine doesn’t matter as long as it’s a 2005 and it’s available.
If you really want a fun k series set up, I helped a buddy do a k24 swap into his EM2. Tsx k24 stock bottom end, acura rsx type s transmission with a 06+ Civic SI LSD, I currently can't remember which cylinder head he used, with some port work, rbc intake manifold, prayoonto stage 4 cams, 70+mm throttle body and it made 274whp on a mustang dyno.
Honestly you really need to do some google searching on k swapping the 01-05 civics, this forum has some info, but there are plenty of other sources online that are dedicated to k swapping these cars. If you want to take this seriously, you really need to start researching what other people have done. Then take that info and see what you can source locally or online.
skyhighsami
07-03-2019 06:08 AM
Xxcivic97xX
06-04-2018 07:58 AM
s2k3_oc08
08-08-2006 09:50 PM
