K20a3 build
Old Nov 13, 2015 | 06:55 AM
Ep3tat98's Avatar
Default K20a3 build
Ok so, I've got a 2003 Honda Civic si ep3 with the 9.8:1 k20a3 roughly 160hp. I was thinking of rebuilding the bottom end. 11.5:1 compression Pistons and new rods. On top of this I was going to get the k20a2 head. My question is, if I change the compression ratio do I need a new ecu that is preprogrammed with that high compression tune? Could I use an oem one from a k20a2? I'm not looking to go crazy with price and performance parts but the 200hp of the k20a2 is a little more of what I'm looking for.
Old Nov 13, 2015 | 08:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: K20a3 build
If you use a stock K20A2 complete cylinder head, and you increase the compression by changing the pistons to one that makes the same compression as a A2 engine has, and use an A2 intake manifold... yes, a stock PRB ECU should work reasonably well.
Old Nov 14, 2015 | 09:17 AM
F22Master's Avatar
Sell your motor, buy an A2.
It will cost you MUCH less in the long run. And less to worry about and go wrong.
Old Nov 14, 2015 | 11:23 AM
Ep3tat98's Avatar
Well I can't sell a motor with a bent valve an have enough to buy an a2. Plus I don't have time to try to sell the motor. What I'm asking for is information not an opinion. Thanks though
Nero 94 Accord
Jul 10, 2013 03:32 AM
Firstoost
Apr 26, 2006 05:30 PM
fastaccord94lx
May 19, 2003 05:51 PM
gshockbreaker
Nov 21, 2002 04:16 PM
