PDA
View Full Version : K Series
Pages : 1 [2] 3 4 5 6 7
  1. EG + euro R fitment questions
  2. 1994 Hatch k20z3 running like poo
  3. K series header
  4. Thermal gaskets vs stock
  5. Differences between K20A engines
  6. Exhaust
  7. Rbb2 head question
  8. 06 TSX Cams Full Specs and k24a2/k20a2 compression
  9. My new K20A2 EK Hatchback project.
  10. K20A: 2001- 2003 problem with 4th Cylinder overheating?
  11. K-Series Parts List For Swapping To 2003 Honda Civic LX Chassis
  12. Will i see HP gains with this Cheap EBAY header?
  13. Return vs Returnless Fuel System
  14. Fuel Injector Source and sizing question
  15. How to make kswap center feed fuel lines for $65
  16. K24A3 Tranny compatibility
  17. Prepping for a turbo k build
  18. Pistons Rods and Cranks
  19. Added oil additive, now rough idle and low rpm hesitation
  20. What are the ITB's of choice?
  21. Suggestions for economy K24 (87 octane)
  22. New K-Series Build
  23. K24 CAD files
  24. K20 swap
  25. 04 Honda Odyssey Multiple Errors
  26. I have an 03 honda accord
  27. K20a3 motor from auto tranny not lining up with K20a 5 speed Tranny
  28. K swap questions
  29. 09 CRV K24 (J) Engine Knock
  30. 05 crv engine build piston upgrade
  31. whats the best but cost effective transmission for a K24
  32. How to Select a K20 Engine and ECU for 400HP Turbo Application
  33. K2o variations
  34. Cast Iron Turbo Manifolds
  35. P0135 code 2009 civic si coupe supercharged kraftwerks
  36. K Series 6-Speed Transmissions: Which to Buy?
  37. Transmission Troubleshooting Help Needed
  38. '97 EK Civic K24 Swap half shaft help
  39. 96 hatch K24 swap
  40. Need help with electrical gremlin under load / VTC
  41. 1500-2000hp k24
  42. K Series swap on 97 EK Chassis Parts
  43. Help with sudden engine noise
  44. No spark on a k24a
  45. Jdm k20a swap.prc ecu k pro throwing p0141
  46. FD2 Sump / Oil Pump Part Numbers Required
  47. Power to wheels cutting in and out, idle surging
  48. mixed up valve springs
  49. K24a non a/c belt size?
  50. Honda Stream K20 engine - Voltage Regulator
  51. Axles for Delsol K20
  52. Scanner only says emissions related tdc but no codes show
  53. K20 turbo possible bad map sensor.
  54. Type R K20a swap
  55. Please help
  56. Sck20
  57. Fuel pump
  58. Need more power on my CRV
  59. Will JDM RSX shifter Cable works for eg kswap?
  60. K series swap install needed in the 757
  61. What part is this?
  62. Not responding when downshifting
  63. Jdm ep3 type r swap
  64. K swap an EM2
  65. CRV K24 engine replacement, what am I missing??
  66. Going K Need Advice on Swap Parts Sales
  67. 96 Integra k20a2 with RBC intake and type-s TB questions
  68. Larger Throttle body that retains cruise control?
  69. best places to find kswap motors?
  70. K24A4 1992 Swap
  71. EP3 6 speed swap
  72. K24Z6 possible to swap into 6th gen?
  73. Swapping K-series into Saturn SC2
  74. jdm k20 into a stock ep3
  75. EG K24 swap motor mounts
  76. Turbo k breaking up going into Vtec
  77. 97 civic k24 with no spark.
  78. B series TPS sensor calibration
  79. K24 Timing Chain noise
  80. K24A4 Turbo?
  81. Axles
  82. K series Oil Pans
  83. Finding the correct ECU for K-Swap
  84. K24a with k20z3 transmission in an eg coupe
  85. K24a with k20z3 transmission in an eg coupe
  86. K for dummies?
  87. K24 swap without K pro
  88. Camshaft options for K Series
  89. K series swap to 97 EK manual tranny chasis.
  90. No EPS after k24a2 swap, ABS,SRS and CC delete. (2003 ep3)
  91. k20 to k24 swap
  92. K24 Swap Help
  93. Dc5 radiator fit dc4 integra
  94. My first k-swap, and I need advice
  95. Turn signal lights come on with ignition
  96. k20c1 main bearings torque
  97. Knock sensor plug question
  98. 06 Si Rough Idle, Shuts off!!!
  99. 2007 Civic SI ticking noise
  100. JDM K20A bolt ons and Kpro Ported RBC manifold>?
  101. Transmission which is best for k20/k24 Frank
  102. Valve train??
  103. Jdm engine
  104. Jdm k24a price
  105. Which k24 motor is better for rebuild
  106. dry sump and mounting angles
  107. K Swap shift linkage
  108. K series throttle bodies?
  109. Seeking k24 guidance
  110. Odd Question, k24a2 short block with k24a4 heads?!
  111. k24a2 and turbo?
  112. Kswap front and rear hubs
  113. Does anyone have or can make a install video bosch ev14 injectors into k series
  114. K24 into 05 type
  115. k20Z3 - Shifting locks at at high RPM or under heavy load
  116. K24 turbo
  117. Stock K20 engine individual throttle bodies
  118. Valve Cover Harness Studs Part #
  119. KTuned Upper Coolant Housing Install(k24)
  120. Just need some advice please
  121. Need help/advice. PLEASE!
  122. Timing/Leakdown and TDC Question
  123. AEM EMS-4 K engine harness?
  124. PLM K24 EP3 Header and Exhaust Fitment
  125. JDM K24A and K20a2(PRB) Oil Pump
  126. K swap
  127. JDM K20 ECU Info
  128. Speedometer, fuel gauge, and temp gauge not working after kswap
  129. 03 accord 2.4 weird p2185
  130. Whining noise K24 2004 Accord CL9 AUTO
  131. O2 heater problem
  132. K20A2 Intake and Accessory bracket
  133. K20z2
  134. Good, Bad and Ugly
  135. Exhaust wrap asbestos question
  136. JDM DC5 K20A Clutch? Aftermarket....
  137. AWD kswap set up HELP
  138. K24 Accord Help
  139. 04 crv engine replacement Frankenstein
  140. stuck key simple solutiion
  141. K20A Type R Clutch Question
  142. Honda swap questions from a BMW guy
  143. Euro r k20 swap
  144. thoughts on my idea of k24 swapping a es300?
  145. New to the forum. Map issue. 2.4. 4 cylinder 2003
  146. IACV wiring
  147. Gearbox
  148. What engine harness should I run?
  149. Type s k20
  150. Still won’t start
  151. Please Help Me Identify These K Series Injectors
  152. K24Z3 with 02-04 accord wiring/trans?
  153. K20A Block Compression
  154. Trans Snap Ring
  155. Use my K20a for turbo project? Or get a cheap K24?
  156. K24 throttle body coolant lines
  157. k20a2 rebuilt
  158. 04 acura tsx swapped engine power steering
  159. K20 em2 not starting
  160. Mk2 Mr2 Kswap
  161. K series timing question
  162. K-swap EK: Help, no spark
  163. Supertech or BC Dual Valve springs and Ti retainers
  164. Cylinder#1 running rich.
  165. Replacing Thrust Washers?
  166. 92 VX K20a2 swapped, header and exhaust questions
  167. How To : K24Z7 swap in EG civic. Complete how to!
  168. K20a3 block boot
  169. half shaft question
  170. K24a2 RBB Head on K20a3 Block
  171. clutch \ flywheel bolt help
  172. K24 76mm turbo too big?
  173. K20A2 valve train
  174. K24a2 exhaust camshaft on K24a4 head/engine
  175. Kswap into Eg, fuel line help
  176. Ktuned swap packages
  177. Just need some help putting a parts list together for a k20/k24 swap in my RSX
  178. to stop all the confusion this is the parts list for swapping k20a2 into ek and what
  179. K24A2 BAR’d swap into EP3?
  180. K20
  181. K20A2 Valvetrain and spring rate question
  182. Might buy a K20a
  183. Bad head gasket?
  184. k24 Turbo
  185. K24 won't rev past 6100rpm
  186. K20a2 semi built drop in or stage2?
  187. K24z7 swap wiring
  188. K24 into R53
  189. Will a K20A2 trans fit a K24
  190. Legit way to smog k series swap question
  191. Basic question about coolant
  192. K series daily driver worth it?
  193. b16 manifold on k20
  194. 1998 Civic K swap
  195. K24 turbo with dragcartel camshaft
  196. Need some information on the k24a engine
  197. Help: Car won’t go into gear.
  198. integra k20 swap cranks/no fuel/no start
  199. K24 honda turbo question
  200. Throttle body adapter
  201. PND K-Pro Reverse Lockout HELP!
  202. What valve spring compressor do you guys use?
  203. K20a3 vtec don't cross!!
  204. K series wiring harness which one is needed
  205. Eg kswap using ep3
  206. Oil Drain Plug Came Out with Oil Pan Threads on it...
  207. K20a3 build anyone done it ?
  208. Parts for k swapping an EK coupe
  209. K tuned shifter bushing
  210. Which K motor will be more fun on the highway?
  211. H Series Or Kseries
  212. K24z7 in a ek
  213. K20a bottem end nocking can you regrind the crank ??
  214. K20 Maintenance Parts Cross Compatability
  215. uncooperating oil rings
  216. is it possible to build this for $15000?
  217. Need help: what is connector plug A pin out #6
  218. K-series exhaust vs awd transfer case vs eg subframe
  219. Honda Insight K swap, which motor? questions
  220. K24/k20 swap
  221. Motor mounts for k20a in eg hatch
  222. k20a Swap
  223. Valvetrain noise k24/k20
  224. K20a2 chamber
  225. k24 vs k20.... LOOKS only
  226. K24 swap with K20
  227. engine swap
  228. k24 block with k20 transmission issue
  229. k24a4 into ej1 questions
  230. Is my 2nd gear syncho bad?
  231. Needing a motor
  232. Oil pump for stock k20z3
  233. Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
  234. Parts needed for a K20 swap into a EJ9?
  235. k24z3 block questions
  236. Engine Rebuild Kit
  237. K24a8 Daily Driver Upgrade
  238. Use a 06 civic si ecu and harness for eg hatch swap????
  239. K24A2 motor compatible with K20A3(EP3) tranny
  240. C27A Pistons on a K24?
  241. k24z9 with k20 engine head?
  242. Honda Insight ECU Pinout
  243. RSX with K24 Swap - Injector Issue
  244. 2006 Accord Noise: Experience to Share
  245. California BAR: K24A2 into EG - need help
  246. About K24A Accord Engine
  247. K24 side mount pulley kit
  248. Help needed datalog attached, kpro'd k24 turbo in 03 RSX
  249. K24a engine looking...
  250. k24z vs k24a confusion
