What Kpro should I be looking at for K20A2 swap?
Hi,
I'm just about to start swaping motors in my EK VTi (B16A2) for a K20A2 engine and was wondering which Kpro should I get, some say Type-R Kpro ECU and others say Type-S Kpro ECU. Another thing is, will the Hasport/Rywire loom/harness for the swap be plug and play or do I need special connectors for those kind of harnesses? I know this has been questioned and answered a million times but I don't wanna make any mistake on this. Thanks in advance.
Re: What Kpro should I be looking at for K20A2 swap?
With K-Pro, you can use many different ECU platforms and alter the tune accordingly to fit your needs. It would matter which ECU you get more if you were intending to use it as a stock ECU without K-Pro.
Check the "Specifications" tab in this link for a list of ECU types that will work for you.
https://www.hondata.com/kpro/kpro-product
Wouldn't he still need the correct ecu that went to his engine wiring harness? I know their is a jumper harness to run a k20a2 ecu with a k20z1 harness but other then that I thought they all run the ecu specific to the wiring harness.
For a "swap" car, the most sensible engine harness choices, regardless of the engine to be used, would be the RSX-S (PRB), EP3 and base RSX manual. Some plugs may need to be changed, lengthened or shortened to make everything work, but they are good foundations.
H-T Premium Sponsor
usually you get the engine harness and ecu to match the engine. so in your case the type s engine harness and ecu.
the hasport harness is plug and play and comes with instructions
