- K-Series Build
- K24 honda civic si 2015
- Buddy Club K20 P-1 Racing Valves
- Help!! E85 in k24, ITB, VTC and admision cam k20....(but stock internals)
- K20a type r swapped em1
- K20 a and b bore and ring gap
- vtec killer
- K20a2 EJ Speedo Not Working !
- EG 93 wideband k series
- k20/k24/S2000 combo build
- K swap EK4
- HI need help identifying some K-Series parts
- help!
- K248A Timing Chain "Slipped" several teeth
- TS HELP. Sounds like running on 3 cylinders
- Stock vs Aftermarket K20 Wrist Pin Question for my F22 build
- Kpro VS Ktuner
- Serpentine Belt keeps coming off
- K24 Swapped Civic.
- Need help deciding compression for new build
- K20 top & k24 bottom
- F.S. K series Eagle Rods
- K SWAP ENGINE HARNESS ???
- Timing chain question
- Help i need the rod torque specs for a K20A6 ?
- JDM dc5 type R with Kpro PNF ecu
- Power steering without AC???
- VTC oil control solenoid
- Clutch or Throwout Bearing?
- Problems with emissions testing?
- Engine direction of rotation
- Em2 turbo k24 daily
- k20/k24 build (CRX)
- What tire setup to hook with built k24?
- How much should a k series motor cost?
- DelSol hood not lining up
- 1991 Honda CRX Si K20 AWD
- K24a8 block build questions
- k20 boost
- Need help ASAP Shifter Cable Question!
- Fresh Kswap with constant charge light ON
- engine swap
- K20 CRX Swap Questions
- ideas for a good set of turbo cams
- k series integra ecu question
- After the “K” swap.
- k24z2 help?
- K24W/HPFP series engines
- K20a2 intermittent VTEC I need some help please.
- 06 tsx pistons in k24a8
- k24 question
- k20a2 crx
- What is the bolt patten for the oil pan K20
- RSP intake manifold advantages and opportunities. Do you want to get to play in this?
- kswap ac system wiring!
- 06 accord headers? ????
- K-swap w/ AUTO trans into non-honda. Need info
- Need HELP!!! Intake with MAF sensor
- K20a2 with bolts on got retuned it
- 93 civic hatch k20 swap
- Question about K-Series in general and swapping into EK/EJ6
- k20 swap eg problem
- obx short shifter vs blox short shifter 05 RSX Type S
- K20a2 manifold on K20a4?
- school me in k series
- K24 swap hatch???
- K sries ignition coils?
- K20z1 eg with k20A2 trans
- K20 93 DEL SOL SWAP
- Ecu
- Rebuild or buy new
- jdm k24 identification
- EK K20 Swap
- JDM K-Swap + GT35r
- reputable shop in Portland oregon
- Price of K Series and B Series - 2014 Market Price
- buying tips for k20/k24 rsx type s
- K20A EG Swap Problem
- K20A2 or B18C JDM Type R Swap?
- shop manuals
- ultra manifold
- My dad and I want to start a project car
- k24 swap in dc2 - what tower strut bar did you guys use to clear the motor?
- K20b into an eg???
- Kswap build thread
- problem with antifreeze squirting out of reserved
- K24a2
- what makes the k20 head better than the 24's?
- Version 2 hasport ekk1 mounts question.
- Ground problems
- Found a salvage rsx type s for swap
- Power Steering K20/DC2 Question
- CT Engineering Supercharger Kit for K20z1
- k20a2 original key and transponder
- What does stock k20z1 valve train look like?
- Is the K20 right for me?
- Gear box binding? Hard to shift
- Fastest SFWD K Series
- Battery Drained & No Speedometer after Tranny Fluid Change
- 09 si won't start
- Duralast clutch
- Injectors and ecu on stock k series?
- K24a8 into ep3 vtec issue
- Need help!! K20 into a dc2
- What is the easiest way to change your clutch.
- K24 & K20 Flywheels interchangeable
- K20 in a 2000 civic. Looking for anyone who has done one recently?.??
- JDM k20 Type R DC5 Cams
- EG with K20a2, having starting issues
- harness interchangability
- Exedy Pull type clutch
- K20/K24 Valve Cover Interchange Details
- 2002 civic si need help
- O2 sensor issue in k pro
- What was your set up before going K?
- Do you put Lube on the Main bolts?
- K24 engine stall problem
- 2006 RSX swap issues
- Speedometer issue k20 em1
- Cam Gear VTC 50* on stock k24 ecu
- 09 si sedan won't start 👀 help!!!
- k24 CKP crank position sensor differences
- 08 TSX CAMS WITH RBC GEARS ON N/A SETUP, NEED ADVISE!?
- does this look bad? (and why so)?
- K24A2 and K20A2 valve/piston clearance !!
- Identify this plug
- K20a2 Dyno. Normal?
- need help torquing rod bolts k20a2 crower h 5148 d turbo engine
- 1995 Civic Hatch - K20 Swap
- 93 Del Sol SI K24 swap!
- k Swap ek radiator hoses
- Ek Rhd k20a Jdm no start has all 3 components
- 99 ek hatck kpr question
- K20A ARP Rod bolt Differences vs OEM
- k20 head gasket replacement
- clicking slapping noise
- k24a2 N/A or Turbo B series (GSR or LS)
- Del Sol Project....K20 Type R with USDM bolt ons?
- K24 EK
- k20a3 worth it
- Help?????Hybrid Racing Unibody FPR Issue
- Honda Stream Absolute with k20b engine-hesitation when accel
- k24a2 best oil and weight
- k24 swap into rsx or ek coupe
- Vtec Killer Rocker arms k24
- Is a K20 swap worth it?!
- ej8+ka24e..need help!!
- 2013 civic SI transmission on eg
- Help Please Belt size for 04 k20a2?
- toda a2's with stock valve springs ?
- 4:4 or 4:2 k20 dc5 final drive
- RRC pistons valve relief
- k20 type s final drive into k20 type r tranny
- Need info pls
- K24z2 block and k20a2 head help guy
- K24Z3, anyone?
- RSX TYPE S K20A2
- Help k20a2
- k20z3 question!
- K20a2 dyno
- Valve lash settings
- 04 K20a2 6spd complete swap
- k20/k24overheating
- 2007 civic si advice
- K20a2 built (injectors size????)
- Standalone engine wiring harness K Series
- Swap maybe?
- boosted k24/k20
- putting RBC on k20a2 and port polishing?
- ????Z3 Cams with A2 Head
- Crx k20 swap question
- Hondata S300 K20 map
- K20a cams on k20a2 (valve adjusment)
- Having problems shifting
- ABS in K-Swap Write Up! *Guide*
- K24a2 do my dyno numbers sound about right?
- K series block build Question
- eg cross member needed for an EM1 (ek)?
- Whats a good budget for a complete k swap?
- Whats the cheapest possible reliable k swap?
- K20a2 with boost. Soon to come!!
- Best K series swap worth the $$?
- Looking for build help
- average cost
- K20 swap into honda stream rn1
- A/c bypass options
- K24 rough idle, knocking, smoking and stalling
- k20a3 long block
- ????????How to change spring on RSX TYPES OIL PUMP
- K series Underdrive pulley Kits
- k series vs b boost financially
- K head on J series Block
- eg6 swap B18c or k20 swap? (circuit) track project)
- 2007 Honda Civic Si RPM Issue....
- k20a vs. k20a2
- ARP K20 Rod Bolt length
- K20a2 Misfire Problem and compression test results
- k20a2.0 vs. k24a 2.4
- K24A1 accord
- k20 swap
- Electrical Issue k20
- looking to swap from b16
- K series to Tremec tranny bellhousing?
- K24z3/K20a2 Info Needed!
- k20z1 in ek help!
- K20A2 vs K20Z3 Head
- integra k swap issues
- EF build
- k24a vs h22a.
- Ek k series swap
- K24 swap
- ram header dimensions
- Build your own Super car with your k20 and 10k
- lil off topic but im doing a raffle for a harness to celebrate the arrival babyg
- K20a3 with pte 6262 oiling
- 13 civic si transmission
- k24z1 axel question
- Best k24 bare small block?
- IDK WHAT TO DO
- KSWAP into ek
- k20a2 integra wont start
- EP3 with K20A2 swap idling issues
- Tunerview RD1 w/ Kpro?
- is there a thread for a k20a swop into a 97civic(keeping the motor compeltly standed)
- hasport esk3 mounts wanted ?
- Help with Stock EP3 Datalogg
- K20a2 CAM ADVICE
- K20A2 Build Questions
- K20 cams Help me to recognize this cams PLS!!!!
- K20 swap problems with car not starting after running
- k20z3 head
- Help with my ep3
- MPG with k swap in ek eg dc
- Going to put a k20 in my crx
- 95 Civic K series
- K20 or k24 swap?
- K20a2 EF swap idle searching problem
- k24 headgasket question
- Engine harness diagram
- K-series swap for EM2 - advice needed (not your usual questions)
- K20 eg no injectors?
- thinking of K
- K20z1 swap into ep3 ???'s
- TPS sensor Honda Accord 2003 (K24A4 series)
- k20 vs k24/k20 stock.
- what engines can i put in a 2006 honda accord
- What to look for when buying a older model honda with a k-swap?
- need help
