k24/20 AWD Integra Build(slow)
Old 01-23-2016, 07:25 PM
estefi357's Avatar
Default k24/20 AWD Integra Build(slow)
Well I've been wanting to do this build for a while now. I have done a lot of research and somethings are not so clear yet.
So lets start off
94 integra rs clean title
I've done a wire tuck and relocated the fuse box umder the dash(dont have pics right now)
I put the battery under the fender/bumper
Tucked the lights harness and installed the hids
Had to replace steering column (now have a ek steering column)
Also a brake tuck
96 prelude center console swap
In these past day i bought a k20a2 with a spun bearing, crv rear diff with axles.
Ill post pics later cuse i got to go.
Old 01-23-2016, 08:51 PM
estefi357's Avatar
Default Re: k24/20 AWD Integra Build(slow)
My tegg crv rear diff and em2 shifter cables(ill talk about the shifter box and cables later)
It spent 250 for a k20a2 with a spun bearing and its about %95 complete. Only got the motor for parts to swap to the k24a2 i dont have yet.
The inside its a little dirty i just installed the dash back (wire and brake tuck)
Prelude center console
Fitting of the prelude center console. Looks great just needs to be trim a little to fit and need to relocat the hand brake. The best part is there's enough space for double din and space for some turbo guages
Cut and weld to extend the hand brake
Integra rear trailling arms custom to fit crv rear bearings. Had to make a braket to fit the bearings.
Integra front hubs on the crv bearing. The crv and civic ex si/integra bearings have the same size inner diameter so they fit without any modification.
I got this specs from the autozone website
Im taking the axle apart and my lil one is cleaning the diff
The outer of the crv axle. I have read the you just need to swap the outer of the of the axles so they fit the hub. Im using a integra front hub to keep the 4 lug because the crv is a 5 lug.<br/>The integra hub is a 26 spindle and the crv rear hub is a 23 spindle. The only thing is that the outer side of the crv axle looks like the inner side of the axle so with that said i need to use civic/integra axle and swap the inner cv axle.
This is how the civic/integra axles look like when taken apart
The crv rear axles both inner and outer look like these. Now you see the problem
Old 02-18-2016, 05:03 PM
JDMxBRU's Avatar
nice!
Old 02-22-2016, 11:59 AM
GoldieWang's Avatar
You are definitely getting somewhere! Good luck and keep us posted
tegra94proj09
Appearance Build Threads
17
05-21-2009 05:05 PM
xCIVICx
05-11-2009 07:36 PM
6spdDC2
10-25-2005 12:04 PM
.water
07-07-2004 06:30 PM
redwinqs
10-04-2002 09:41 AM
Quick Reply: k24/20 AWD Integra Build(slow)
