04 Accord 5 speed wont shift into gears!
I have an 04 Accord K24 5 speed with 75K miles. So this car has been giving me issues by not wanting to change ito gears. So i brought the car to a shop and they replaced my "hydrolics" so my master and slave cylinder... not sure what else. I spent 600 on that. Than 2 weeks later i get the same issue. This time its my clutch. So i get the Exedy OEM Kit and get the clutch replaced. Now a week later the same issue happens. So i park the car. Then later that day i go to start the car in gear and it wont start in gear only in neutral. Then i also feel the clutch peddle feel very light. It comes back up but it doesn't feel like it's getting pressure. I open my hood and the reservoir where the break fluid goes to the master cylinder is empty. So i put break fluid start the car pump the clutch but still nothing. I got the master cylinder replaced twice in a matter of 1 month. ANY IDEAS OR SUGGESTIONS?! PLEASE HELP!
Re: 04 Accord 5 speed wont shift into gears!
Re bleed the system and watch for leaks. If you have air in the clutch line, the pedal will feel weird.
Ernesto C Perez
Transmission & Drivetrain
10-05-2017 10:26 AM
