View Full Version : K Series
- ACTUAL K24A2 PISTON CC's???
- cams (k24a2)
- Jack Mardikian - Made the K-series owner Proud
- anyone with a 06+tsx head or +1mm valves with big cams?
- K20A All Motor Build Suggestions, Parts, WHP
- best k series combination using OEM parts
- K20A VS K24
- my k24 em1 build
- Camshafts for a Dirt track racer for Holland!
- what is the average cost of k swap without the motor and transmission?
- K swap Shifter mounting issues.
- k skunk2 manifold question
- K24A4/8 budget build?
- K24a8 or k24a2?
- Joser's Built "K"
- K20z1 swap into 97 Civic - Is $7K a good deal?
- 2010 World Cup Finals Event Coverage K-Series Compilation Video
- What main rod bearings do i use?
- Video-Ricky Vanzant/RLZ Engineering True Street Civic 9.26@161 mph
- K24a2 Rebuild question
- k20 coil pack problems
- k24 questions
- z1 cams on an a3
- King Motorsports OEM K20/K24 build 06 SI
- what pistons?
- Question about rack and pinion
- "vtec killer" build questions
- k20a2 k24 crv bottom end kpro Map? Anyone
- Where did you get your K20A2/Z1???
- Do they mke Itbs for k24a2
- Prototype Intake Manifold & Header Testing on K24 and K20A and more...
- Best K combination?
- Cannot find info. Difference between K24A2 & A3?
- d series Alt
- K24a4 exhaust
- K23A1 swap?
- Help Please....2010 Si K-Swap Into EG
- awd k20 eg
- 02 SI Clutch Question
- k24 block issue
- K20/K24 injector sizing HELP!
- Stage 2 vs Stage 4 cam testing
- tsx k24 in a ek with AC?
- k24 swap into 89 crx si
- k24a4 with a2 rods/pistons.
- Hybrid Harnes problem with Pra Ecu
- Help everybody Please
- Hi K engine guys.. need some specs PLEASE
- opinions please??? k20 trade or not?
- 02 civic..auto k swap?
- 2 3/8 vs 3 inch exhaust help
- tps/map sensor issues
- FINALLY got the K-Pro!
- want to buy K20A3 motor
- hondata reflash question
- PRC ecu wiring difference? dc2 with hybrid Racing harness
- K20 to K24
- need a K series builder on east coast
- k24a2 EG problems, need help
- what is this ?
- Manifold questions
- go k20a type r or k24a2? need help
- where can you buy the full k20a2 swap?
- K20 swap headers
- a2 & a3 differences
- k24a3 advice
- Humble Performance All-Motor K24 Hatch Finally hits 10's !!!
- i have a question...?
- HELP ME PLEASE
- EG kswap header on EK with eg subframe fit?
- WTF?
- What to look for?
- K24a4 questions
- what cams to run?
- k-series auto?
- allmotr42788 build thread
- K24/20 build need help!!!
- K24Z3 + K20Z3 head possible?
- k24/k20 build info
- How much will a K Swap Cost?
- Another axle question.
- K Swap EG no spark
- K20 all motor rebuild question
- type s swap to a 04 ep3
- which will make more power?
- VSS...
- transmission issues
- need more umph
- K24 QUESTIONS
- k20 swap need help.
- K24a2 Crank needed for F20c Stroker kit
- 09 Civic Si K24 Build 295hp, 213tq DYNOJET FTMFW
- Performance Header ?!?!
- K20 swap
- 91 accord h series or k?
- Toda parts
- k20a3 itb's parts
- K swap in an ef
- DIAGNOSTIC PLUG????
- 286whp/192tq Stock Block K20A Dyno Graph on Pump Gas
- jumping vtec switch through vtec solenoid
- 2008 Accord 5 speed tranny into Integra?
- K20 with A/C?
- PRB VS PRC same or different
- 325hp N/A K24.. IPS Goodies!!
- K-series block machining specs
- k20a3 BLOCK vs k20a2 BLOCK
- Opened my z3 tranny and this is what i found
- K Series worth it?
- k turbo parts
- k motor itb's
- K SWAp NOOB
- Rebuilding Torque Specs
- will this fuel set up work?
- Is this K20A2 head repairable?
- K20A3 main bearings vs. all the other K series main bearings
- replacing k valve cover gromets?
- need help k20 engine harness
- A3 Cam question
- K series Race videos
- k24 Build help needed
- Kelford Stage 1 Cam Test K20A2
- k20z3 swap help.
- here is what fits what
- K20 Info
- k20 swap
- fully built k20a3 vs k20a/a2
- Some one help with k20a3!
- K20 factory trigger wheel
- New to site, I haz serious problems with K24
- stroker crank - what rods?
- K Swap DC radiator the affordable way
- TSX main wire harness.
- want to see k24 build,dyno and 1/4 mile times
- k20k24 build oil pump plug hole?
- K series remflex gaskets
- overheats after build helppppppp.........
- are oem k headbolts thicker than b series?
- ticking noise
- Shift linkage failure
- need some opinions on honda element motor??
- R you running a k24a4?
- k20 with itb's and 150 shot
- Adapter for Skunk2 Intake Manifold on K20Z3
- Block Rebuild, Help Please
- HELP A NOOB TO K MOTORS...NEEW SWAP ADVICE
- K20A2 ECU OPTIONS
- Need help removing K-motor from '04 Integra?
- What k series to go with?
- Let's talk TPS failures
- Return system on OEM/Stock Fuel rail
- K24 - No EFI, No Carb.....
- k24a8 questions?
- BluePrint Stg 3 Cams
- K-series Cams and VTC
- k20z3 all motor build
- Engine Bracket
- need help identifying camshafts
- K20a3 engine harness on K20z3 swap...
- Best OE cams for a k20?
- K series engine in rwd
- k20 or k24
- parts list
- Si into RR
- Other K series tuning options?
- K cam swap in 15 minutes (how-to)!!
- rbc manifold Question
- Compression ratio whats the difference?
- Is 700.00 for k20a2 ok?
- pics and info of anyones k24a4 swaps
- Best way to build a N/A K-Frank?
- help me help my brother k motor gurus thank you
- Compression,Head Porting, Valves & Boresize?
- Long Vs Short Block K24a2
- K20a3 swap to k20a2?
- k24a4 worth swaping stock?
- Building The Engine On The EP3
- motor swap
- k20 or k24
- Can anyone supply me with a pic of the KPro port?
- Depin Injector clips..
- accord harness to kpro
- one thread to settle all my confusion about the kswap
- The BEST axles for EKK1 mounts?
- Speedometer Correction
- K20a3 Max RPM???
- trying to learn...
- Question about swapping k20 into ek coupe
- k24 blocks?
- K20a2 swap.
- ASP's 338 whp all motor K
- K-swap Question
- NOOB TO K
- Anyone running an ERL k24?
- K20z3 EG
- FS: K Motor Parts ONLY
- k20a2 swap or rebuild gsr engine?
- MODERATORS make an wtb/wts/wtt THREAD.. please?
- K24/K20 swap on EG
- mods for k20a3..
- OEM cams in "vtec" killer style?
- k24/ k20 or k20
- Mounts:Hybrid Racing/Starter Kit Feedback
- JDM TYPE R O2 SENSOR QUESTION
- K Powered Integra Exhaust
- Which K20?
- K series axles
- k24/k20a reliablity
- k20a3 A Good Block To build?
- K20a3 eg.
- can anyone name this sound coming from my k20?
- speedo cable help
- usdm k20a2 vs jdm k20 type r
- How much does a K20a2 sell for?
- Help with my 7th gen. Civic K swap?
- Is anyone still using the VTEC solnoid when using VTEC killer cams?
- Official: K24 block, K20 head build info
- k24 miss/studder
- 280hp n/a k24
- K24 engine rebuild
- Import a K20A or modify the K20Z3?
- k24/k20 head question
- k20z3 stage2 cam tuning help
- k20 engine question
- k24a4 ?'s
- Another Simple K24 Setup (DYNO)
- TSX Rod Bearing Question..(K20/24 Frank Build)
- k20 into a 96 integra illegal or legal? need help
- K20a2 vs k20a (type r motor)
- K24a1 block + K20a2 head, all stock... safe redline?
- k24/k20 build with dyno numbers
- Another cam wear tread, K20a2 with skunk2 Stage 2
- K-series cam swap in 15 minutes
- K20A2 into 93 eg hatch
- K20/eg state ref ?
- k20 automatic swap in an ek
- How much does a full K20 w/LSD swap cost?
- 300whp+ IPS k24a on 93 octane : Making the impossible possible.
- K24 drivetrain size/shape
- 312whp k24a / k20a2 Toruku Cams
- Complete k24a / k20a2 engine build guide
- My K25a dyno vs k24a vs k20a2
- 290 whp K24a waiting to inhale
- New project: S2000 engine to K20 transmission
- IPS-KXV cams :New Racing cams from IPS for K series Race motors
- IPS 2006 Civic Si R&D Platform
- K24 363whp on Church's Dyno
- k20a2 swap in 1st Generation Civic
- 270whp K24A / k20a2 Recipe with dynos
- K24 EK Switched to Boost, Dyno run inside...
