Transmission & Drivetrain Gearboxes, Differentials, Clutches
bad axle or diff?
Old Apr 13, 2010 | 04:54 PM
bigG's Avatar
Default bad axle or diff?
i have been hearing noise coming and going almost like a control arm bushing gone bad and another noise like a tire starting to seprate but it comes and goes and onle when i turn right or even switch lanes to the right .... well will inspecting my car the only thing i found was the axles have alot of play up and down in the trans... i was thinking my diff is going bad but then i thought when i shake one axle the other should move to then but that is not the case... anyone have a clue whats going on... and btw this is alot more play than just a 1/4 inch
Old Apr 14, 2010 | 01:28 PM
bigG's Avatar
Default Re: bad axle or diff?
anyone?
Old Apr 15, 2010 | 04:47 AM
bigG's Avatar
some1 help me out
Old Apr 15, 2010 | 07:53 AM
ilikehonda's Avatar
is the knuckle moving or is it the shaft? if it clicking when you turn it is an axle most likely.
Old Apr 15, 2010 | 02:02 PM
bigG's Avatar
now it does it sometimes when im straight but at low rpms when im cruising in 5th or im gettinging off the gas in any gear and it has got alot louder im starting to think the inner cup there is no play in the wheel up or down all bushings are tight and both ball joints and all 4 tie rods
Old Apr 16, 2010 | 05:36 AM
ilikehonda's Avatar
if there isnt much play up and down id jack the car up, crawl under it and play with the axle. id bet its just a bad knuckle.
Old Apr 16, 2010 | 05:50 AM
bigG's Avatar
yea both have have alot of play on the inners but it seems like they are moving in the trans im going to put it on the lift tomorrow and try to see if i can hear it
Old Apr 20, 2010 | 06:14 PM
jdmzach's Avatar
did you figure this out? im kinda having the same problem i think
Old Apr 21, 2010 | 06:14 AM
ilikehonda's Avatar
there will be some play at the inners...nothing to worry about.
1992honda
May 5, 2011 06:20 PM
WhiteOnRice
14
Sep 26, 2006 10:16 AM
turbotime
Oct 4, 2005 06:19 PM
GReddy SI
12
Jul 17, 2003 04:07 AM
Greyout
Jan 21, 2002 02:00 PM
