Transmission & Drivetrain Gearboxes, Differentials, Clutches
Odd problems with b16a tranny
Old Mar 24, 2010 | 03:26 PM
honda209's Avatar
Default Odd problems with b16a tranny
so i guess i can make my own threads already...
My problem is, everytime the car is cold the feel to the clutch pedal is weird, its too soft and should i say saggy? Also It wont go into gear even if the car is off. The stick shift is super hard and wont into gear or it wont go into neutral if the was turned off with a gear in, no matter which one it is.
It is not until the car warms up that i can put it into gear and once its warmed up to reg temperature operation it shifts fine and with no problem at all, the feeling of the clutch pedal also goes back to normal.
can this be due to a lack of oil going into the tranny? or maybe the cylinder or sleeve??
i have a 92 civic with a complete swap from a 95 del sol vtec
Old Apr 5, 2010 | 11:19 AM
sleepencivic's Avatar
Default Re: Odd problems with b16a tranny
bleed the slave(check for leaks), if that doesnt help replace the slave, if that doesnt help replace the clutch master on the firewall(check for leaks inside), if that deost help it in the tranny. done!!
allmotor2.1
Mar 3, 2008 06:02 PM
TwoPointZero
Dec 29, 2005 03:19 AM
TKL
14
Nov 11, 2004 09:27 AM
95GSRTT
Aug 16, 2004 04:34 PM
mchuang
Mar 9, 2004 05:14 AM
