Transmission & Drivetrain Gearboxes, Differentials, Clutches
Name That LSD
Old Apr 24, 2010 | 02:44 PM
DOHCarp's Avatar
Post Name That LSD
I posted this in the Drag forum, but figured it would be better suited here...sorry for double posting.
I just put an LSD i had laying around in an old YS1 cable Trans into a Hydro GSR trans. The problem is the VSS gear works for about 10 minutes then stops. Every time i pull the VSS out it is ground up and destroyed (see Pic below)
Im wondering if I need a special VSS gear for this LSD. I checked all the spacing and it goes in fine but I've had it apart 3 times and destroyed 4 VSS gears. So if anyone can help me out with what Brand LSD or why im having this problem it would be much appreciated. Thanks
Old Apr 25, 2010 | 10:55 AM
DOHCarp's Avatar
Default Re: Name That LSD
ALright MFactory helped me out in another thread and it seams it is a factory JDM LSD. (thanks MFactory) Now is the JDM LSD VSS any diffrent than a USDM VSS? Could that be why my VSS is getting destroyed? or could their be another problem? Thanks.
Old Apr 25, 2010 | 12:05 PM
xzodiackillerx's Avatar
I may have one for you ... I will look tomorrow
DOHCarp
Oct 21, 2010 08:59 PM
zimmy709
Jun 25, 2008 04:06 PM
CR-V-tech
Oct 29, 2003 05:37 AM
Sleeper32
Oct 21, 2003 10:53 AM
