Transmission & Drivetrain Gearboxes, Differentials, Clutches
what tranny is this
Old Mar 24, 2010 | 04:21 PM
mhewitt's Avatar
Default what tranny is this
i bought what i was told was a civic type r tranny, the case says s4c and its lsd but when i opened it up n counted the ring gear it was-64 and the final drive was-15, so thats a 4.26 gear ratio right? isnt that low for type r? i also counted the number of teeth for every gear on both shafts if no one can answer using this info i will post the rest.
Old Mar 24, 2010 | 04:24 PM
mhewitt's Avatar
Default Re: what tranny is this
countershaft-1st-42 input shaft-1st-13 (teeth)
2nd-40 2nd-19
3rd-35 3rd-24
4th-31 4th-28
5th-28 5th-33
Old Mar 24, 2010 | 04:28 PM
mhewitt's Avatar
also i need to replace the ring gear and final drive cause they r both tore up. any suggestions on where to buy them and what ratio would be best for my setup:
b20vtec 12.0 c/r,skunk2 stage2 cams, dc header,2.5"exhaust,skunk2 pro series i/m n 68mm t/b. runnin a 205/50/r15 tire for street/strip use so nothing to aggresive but good in the 1/4
Old Mar 24, 2010 | 05:11 PM
mhewitt's Avatar
it also has 15 bolts in the ring gear
Old Mar 24, 2010 | 06:27 PM
mhewitt's Avatar
help me
Old Mar 24, 2010 | 06:32 PM
mhewitt's Avatar
anyone know about weird trannys? lol
Old Mar 24, 2010 | 07:22 PM
mhewitt's Avatar
bumppp it up
Old Mar 24, 2010 | 09:39 PM
mhewitt's Avatar
bed bump
Old Mar 25, 2010 | 01:43 AM
Mista Bone's Avatar
D Tranny Guru
too many bumps to help.
Old Mar 25, 2010 | 03:47 AM
david974's Avatar
http://shop.synchrotech-transmissions.com/
they have some final gear make you choice and they will help you
another for ratio
http://www.teammfactory.com/gear-calculator
hope this help
Old Mar 25, 2010 | 07:45 AM
mhewitt's Avatar
kinda need to know what tranny i have so i know what to order the gears for nobody seems to know about a 15 bolt ring gear for honda lsd
Old Mar 25, 2010 | 07:53 AM
v.ice1's Avatar
it is a type r tranny for sure since its s4c and if on that same stamp it says LSD well it typre r but if the LSD isnt from factory well it looks like a S.i tranny,those are really short gears gotta find from which type r is it from,spec ect...
Old Mar 25, 2010 | 03:22 PM
mhewitt's Avatar
called mfactory and they dont sell ring gears for the 15 bolt or the 14 bolt honda ring gear lsd. so i would also have to buy a new lsd in order to get the stuff from them. does anyone know anywhere that sells ring gears for the 15 bolt design? or maybe a final drive for my spare lsd which is a 14 bolt honda lsd with a 66 tooth ring gear?
Old Mar 25, 2010 | 08:06 PM
mhewitt's Avatar
bumppp
Old Mar 26, 2010 | 07:33 AM
mhewitt's Avatar
will si final drive work with the 66 tooth type r ring gear?
Old Mar 27, 2010 | 04:25 AM
Natural Aspirations's Avatar
That sounds like an SiR LSD not an Type R LSD
It has b16/ctr/USD ITR gear ratios with an SIR LSD and an LS final drive.
Sounds like some pieced together a pile of parts.
H-Motors is one of the cheapest places I have found the OEM 4.7 ITR final drive.
I would also try to source a used ITR LSD and go that route if your on a budget.
Old Mar 27, 2010 | 07:03 AM
mhewitt's Avatar
u talkin bout the 15 bolt 64 tooth ring gear lsd is an sir? or the 14 bolt 66 tooth ring gear lsd? i can use the spare 14 bolt 66 tooth lsd i have then i would just need a final drive that works with it. so what f.d. do i need to buy?
Old Mar 27, 2010 | 07:20 AM
I suspect its a SIR viscous LSD which as far as I have seen no one makes a replacement final drive for.
Some info here:
https://honda-tech.com/forums/transmission-drivetrain-127/itr-lsd-into-b16-tranny-%2A%2A%2Ahelp%2A%2A%2A%2A-2570962/
Old Mar 28, 2010 | 07:15 AM
mhewitt's Avatar
thanks that info helped some especially the part about the ls countershaft not working with type r 66 tooth gear because i was gonna try it seeing how i have one laying around n it is 15 tooth. so i have to get an si 15 tooth countershaft to work with 66 tooth type r ring gear. in order to use spare lsd. but if iwanted to use my current lsd (4.26)ratio i would have to find a rare 64 tooth 15 bolt SiR ring gear but then could use the 15 tooth ls countershaft with it. did all that come out correct???
Old Mar 28, 2010 | 09:51 AM
mhewitt's Avatar
right?
Old Mar 28, 2010 | 10:13 AM
Both parts should be from the same set. Mixing gears is not advised.
Old Dec 28, 2022 | 10:16 AM
Corky21's Avatar
15 bolt b series lsd’s/ ring gears and unique to the b16 88-91 y1 cable transmissions which were optional lsd’s. they run the small spline clutch discs. If you still have it I’ll buy it haha. If this was found in a hydro case someone swapped the gear set into it.
gilou bilou
Nov 11, 2005 09:05 AM
integramic
Jun 4, 2004 03:22 AM
zbower7
Feb 21, 2004 12:02 AM
