- Chassis
- 05 Civic 1.7 #3 misfire
- 2001 civic clicking noise when coasting/slowing down
- 03 Civic Climate controls NOT WORKING
- 2003 Honda Civic Hybrid throwing P1655
- HELP: I need help Finding what the retaining clip is called on top of fuel pump;
- Battery light stays on
- Speakers not working
- Right high beam doesn’t work
- First post new to the forum
- Radio issues.
- 2002 honda civic problem
- Manual Trans Pops out of 2nd gear
- 2002 civic HELP four door 1.7 litre delete ac PLEASE
- Short term air/fuel trim messed up
- 2002 Civic 1.6L, alternator output 12.7v.
- No Dash Info and Stuck in park
- 2001 honda civic lx passenger door lock pin/clip
- Tough Troubleshoot
- 2001 civic ex coupe
- Help with k series Transmission
- Honda civic transmission
- 2004 Civic LX power steering whine
- 2003 Honda Civic Small Red Light Cntr Console
- Over heating
- Does the ECM change ignition timing and fuel mixture with bad downstream o2 sensor?
- Vibration in steering wheel
- Honda Civic ep2 won’t stay running.
- Leaky Exhaust valve help!
- 2002 Honda Civic Ex
- Intake manifold clogged
- What new transmission for a 2003 Honda civic executive to make 170hp
- 2003 Honda civic ex coupe condensate drain leaking coolant
- Need help!! Fans not working unless jumped or A/C on (only for 1 minute)
- Trying to identify plug
- Please help me find out where this sound is coming from! (Video included)
- Honda Civic Dimension 2001 shifting problem
- 2004 Honda Civic DX power distribution box (fuse box under under) wiring diagram
- 2002 Honda Civic battery light flickering new battery/new alternator
- Limp mode
- Maintenance questions
- Civic 2005 key fob reprograms successfully but does not work
- What is my car worth?
- 12v light and IMA light after getting BOTH batteries replaced
- Need help with power steering
- Engine and head combinations
- Economy Remap on 55 Civic 1.4 SE
- Anyone know of a seal conditioner that works?
- EP3 Style Spoiler
- HELP extra bolt
- APPLE CARPLAY HELP
- Help
- Immobilizer and key
- Ep3 Type R skirts on EM2 (Possible?)
- Heat issues
- Lurching sensation in 3rd gear
- 01 civic No power
- D16y8 Intake Manifold on D17a2 (I think?)
- 2001 Honda Civic Swing No Start
- 01-05 Hybrid 1.3L Manual Clutch?
- P1298 code secondary code
- C0300 code on 2002 EU8, no performance issues
- 2005 Sedan Door and fender swap
- 2002 Engine into 2004 model
- rough shifting
- Should I have the tranny fluid changed?
- 2004 civic lx transmission on a 2005 civic ex??
- Car starts and idles until warm, then sputters and jerks once in gear.
- Headlights
- 2001 Civic HX starts and idles fine but stalls under load once warmed up
- engine light
- Need help determining source of oil leak
- Swapped Transimission For JDM.
- Engine seized up???
- No flow to upper radiator hose, water pump checked, good, new thermostat, flushed rad
- Lifter noise/loss of power/stalling/overheating
- 01 civic ex Kswap and manual swap
- TRANSMISSION PROBLEM
- 2005 Civic Flashing Green Key (Crank No Start) Please Help
- ECM Part Numbers and Replacement
- broke my front axle. stupid question. do I have to tow this home?
- 2003 Civic EX dashboard gauges malfunction
- Freeze plug on head missing after machine shop. Will JB weld hold??
- Squealing noise mainly when dowsnhifit
- No brake lights 2004 Civic
- I have a strange problem with my 2004 civic lx with the transmission.
- PLM-L04 Pinout - 2004 Civic EX
- Honda civic
- 2002 Honda Civic EX Crank No Start
- 2001 Civic Camber
- 2003 ex vs 2005 lx VVT Solenoid
- can't find parts in South Africa
- 2001 Automatic Honda civic DX changes gears but doesn’t move
- 2004 Civic has spark and timing is right, won't start
- Looking to Buy Civic - wierd noise on acceleration
- Boosted d17a1
- How big of rims can I go?
- 03 civic ex has no power on acceleration
- 2005 Honda civic lx coupe automatic 02 sensor
- Need Help With Stalling Tried Everything - 2005 Civic
- 03 Civic EX complete rebuild help and advise
- Anchor for engine mount
- 02 Honda Civic EX Transmission
- 2001. Honda civic timebelt tensioner bolt hole is it fixable help!!!!!
- Throttle body swap with JDM engine
- Codes P0108 and P0113 After Valve Adjustment
- Code on radio
- Weird sound while coasting
- need some advice here. car is dead, thinking of part out?
- 2002 Honda Civic ex coupe, is this damage repairable if so what's the estimated cost?
- Where to buy after market car parts?
- 2003 Honda Civic lx 1.7l starts rough but dies after idling up
- 04 Honda Civic clutch problem
- Engine Knocking on Heavens Door
- 2001 Honda civic ex wont shift past reverse? please help!
- Civic 2004 - Auto Trans
- What's going on?! , 😭
- Honda Civic LX 2001
- Schematics
- Throttle cable loose from gas pedal.
- 2002 Civic SI - Disconnecting VTEC valve electrical connectors
- Running slightly rich
- Honda tires
- P1259 DTC: VTEC quit working
- 2004 Civic EX Auto
- '05 Civic front driver turn signal light stays on but won't flash
- Car shuts off at a stop, multiple engine codes.
- Intake /ram air/plenum needed ?
- 2001 civic LX
- 2003 Civic DX Problems
- 7TH GEN SPECIFIC Ball joint kit + adapters
- 2005 Civic Coupe - Issues
- ALL POSSIBLE OIL LEAK POINTS on a GEN 7 CIVIC
- 04 odometer mileage only not lit up.....
- 2002 EX Cluster in 2004 Value Package?
- EP3 EPS and ABS light turns on
- Recent ignition interlock install causing problems
- Alternator charging @ 11.5v. Running fine. Should I expect trouble?
- 2002 Civic EX P0301
- Cooling hoses
- Head Gasket Issues
- 2001 odd idle issue
- heater issues
- 2002 Civic SI (hatchback) transmission leak
- Battery postive cable routing.
- Ep2 ECU pinouts
- Odd A/C issue
- Ignition Tumbler Issue
- Honda Civic 03 D17A1 to D17A2 question
- 👋Hello all of my Honda Fans 🤜🤛 bmxa trans help
- 2005 Civic fuel pressure
- 2004 Honda civic hybird won’t start or crank
- Cracked EGR valve?
- AC nightmare help
- Engine and ECU swap help
- Oil Block
- Can someone help me Identify this distributor?
- I just put a 2001 LX 5 speed on the road and there's a few issues
- Hazzard not working Honda civic ep2 2004
- 5th gear pop out advice
- Coolant leak above oil filter! Need to resolve ASAP!!!
- '02 Civic Hood Release Replacement -not broken plastic-
- Honda Civic 2002 Strange High RPM, Misfire and Gasoline Smell
- Misfire on clyinder 4 after head gasket
- Cranks but wont start
- Bad Clutch?
- In Cabin Fuse Box 2004 Honda Civic
- Wipers issue advice
- 2002 civic sir 2l loping idle
- right front vibration
- Few questions about my 2004 Honda civic vp 😁
- Front passenger tire wearing on outside edge
- 2005 SiR 2 door hatchback window regulator issues - could use some guidance
- 2004 Civic EX shudders coming to a stop
- 2001 Honda Civic LX Coupe M/T OBD not reading has power.
- Will a k24 harmonic balancer bolt fit my d17a2
- Crankshaft Bolt Broke off inside on takeoff
- New (remanufactured) transmission won't go into reverse
- Freon refrigerant question
- MICU question! Please help
- 2003 honda civic ex tail lights
- Any Suggestions??? Drive light issue
- trunk leak troubleshooting
- Attempting S20 trans on 04 civic
- 2003 civic won’t shift past 4k rpm’s!
- 2005 Civic DRL Issue with LED Headlights
- broke ear off bell housing. thoughts on success of welding on?
- new to me car. no start, coolant blown out of radiator.
- Temperature guage almost reaches Hot when idling
- Power steering fluid OEM brand
- Camshaft pulley bolt replacement
- DLC connector not communicating
- How to remove plastic panel
- Got an interesting problem on a 02 Civic
- Redundant timing belt replacement
- 2002 CIVIC SiR hatchback
- 03 Civic Radio Switch, Harness Radio Not Clear. please help
- EP3 with a few problems. Need help.
- Engine computer
- Door Lock Issue
- A/C Head Scratcher - SOLVED
- Transmission swap
- Ep3 6spd swap help me! Lol
- Civic 2001 gauges went off and now car won’t start
- AC stops cooling
- Alt plug wiring
- 03 Civic fan problem
- Bypass immobilizer
- suspension bushing kit 2001 honda civic
- 05 Si hatchback misfires
- Is the 2001-2005 Honda Civic a generation I should modify and daily drive?
- New valve cover gasket leaks
- 2003 good battery no crank
- 2005 civic clicking noise when driving low rpm
- 05 civic Water pump bolt sizes
- 2002 Civic DX ignition key alarm and intermitant wiper out
- 04/05 front sway bars
- 2002 DX instrument lights out
- 2005 Civic DX Power Steering Questions
- 2002 Civic SI - Engine denomination
- 2003 Civic Ex overheating
- Maybe speakers aren't blown
- Under the hood insulation pad
- 2004 Manual Transmission Help
- cooling issue
- 02 Civic flywheel coming apart?
- Radio install
- 02 Civic EX fuel pump issues
- Time-Sert question
- 02 civic ex coupe heat/ac not blowing dials dont work
- '03 Civic Hybrid electrical issue?
- Anyone have info on 05 civic vp interchangeable with other makes and or models?
- no power at A/C compressor
- Wheel spacers
- Help with lambda probe on d16v1
- F (12P) under-dash connector location
- HELP!!!
- 2005 Civic Lx Special Edition
- 2004 Honda Civic LX automatic - Smoke from under hood
- long crank before car starts
- Engine bay squeak when first minute car starts often
- Car wiring issue 2005 honda civic dx
- Dashboard wiring diagram
- 2003 Honda civic lx engine upgrade
- Bmxa trans assembly instructions
- 04 honda civic passenger rear door handle replacement
- 2002 civic lx 4dr - gauge cluster lights partially out. Bulb issue or fuse issue!
- Flood damage inquiry
- is my dashboard shot?
- Oil leak 2002 Honda Civic
