Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
problem with em2
Old Dec 29, 2006 | 04:27 PM
Azn Mug3N (01 em2)'s Avatar
Default problem with em2
I was driving home from work and my ABS AND SRS lights came on and all my meters failed. My car was still fine. When i got home, i could not start my car. Does anyone know whats wrong?
Old Dec 29, 2006 | 07:09 PM
briq4's Avatar
Default Re: problem with em2 (01 EM2)
When is the last time you had a new batttery?
Old Dec 29, 2006 | 07:44 PM
InanimateCarbonRod's Avatar
Default Re: problem with em2 (briq4)
Another culprit could be the alternator.
Old Dec 29, 2006 | 09:14 PM
Boilermaker1's Avatar
If everything but the cluster works, run diagnostics on the gauge cluster.
Im assuming all of the meters failing to mean you have no tach, speedo and gas gauge, and not accessory gauges that you added.
If there's error lights on and no moving needles, I vote for cluster short out.
Old Dec 29, 2006 | 09:34 PM
when i step ont he gas the battery light shows and the engine check light comes on...and my tranny is fucked up making wierd sounds and shaking the whole car..everything is messing up in one day..and yes i prolly need a new battery too..
Old Dec 29, 2006 | 10:34 PM
charlesvsi's Avatar
I'd check fuses, some under dash and some under hood.
Old Dec 29, 2006 | 11:24 PM
LowTec MOHawk's Avatar
that problem your having is very typical of a charging system problem. have your battery tested along with the charging system. (cluster short is very unlikely however possible, start with the charging system/battery)
Old Dec 30, 2006 | 09:10 PM
my transmission also makes sounds too..
Old Dec 31, 2006 | 08:02 AM
petty$rep's Avatar
Default Re: (01 EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01 EM2 &raquo;</TD></TR><TR><TD CLASS="quote">my transmission also makes sounds too..</TD></TR></TABLE>
automatic or manual? what kind of sounds, and when does the tranny make these sounds?
Old Dec 31, 2006 | 02:56 PM
i just installed a new battery and everything is running fine and my transmission stopped making noises..but the battery light still pops up sometimes ..when i start my car and step on the gas
Old Dec 31, 2006 | 04:08 PM
have your chagring system tested at kragen or autozone
Old Dec 31, 2006 | 05:58 PM
briq4's Avatar
Default Re: (mikeformos03dx)
Slipping belt?
Old Jan 1, 2007 | 04:51 PM
i know its my alternator now..i had my car running and when i took off the positive it died..if the alternator was good it would have kept the engine running correct?
bwindsor
Apr 29, 2013 06:19 AM
shot_them_all
Dec 6, 2011 04:43 PM
Supremee
Feb 21, 2008 09:35 PM
my92hondasucks
11
Jul 26, 2006 03:54 PM
wizzards581
Sep 22, 2002 10:34 AM
