Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
HID Problem
Old Feb 12, 2009 | 12:46 AM
DC2 Maggio's Avatar
Default HID Problem
Hey guys just wondering if you have any input on a problem I ran into tonight.
I've installed hid's before on my interga and a few other friends cars so I'm not a rookie at installing them. My winter car is a 2003 Honda Civic, I purchased on of the cheaper H4 HID Kits. I installed one side and when I was finished I went to check to see if it worked. I turned my lights on and nothing happened, I then figured the polarity may be reversed. I then switched the polatiry on the ballast, and then tried the lights. The hid bulb turned on for about 10 seconds and then suddenly stopped working. I turned off the lights and tried it again, the bulb turned on for 3 seconds and went off. I kept trying, and it kept shutting off after 3 seconds.
H4 Bulb
I was thinking maybe I need to take the DRL's out, but that didnt work either. I'm stumped on this one guys and have no clue what it can be. I don't think the kit is faulty, but I can't seem to see what else it can be.
If you guys have any ideas that would be great. Thanks.
Old Feb 12, 2009 | 12:58 AM
DynastyRacer22's Avatar
Default Re: HID Problem
is it a relay harness? most of the time if that happen, from what ive read on the12volt.com they would use a relay harness to power them on but i could be wrong
Old Feb 12, 2009 | 06:36 AM
Hatorade's Avatar
no, i had those on my car last year and i didn't need a wiring harness.
When it lights up, which light works? the low beam or high beam?
Old Feb 16, 2009 | 04:48 PM
killercrx91's Avatar
Yeah you need an relay harness... That's really it.
EJ1 RaceBound
Honda Civic (2006 - 2015)
11
Sep 29, 2011 08:13 PM
dc4teg95
Lighting
Feb 2, 2011 03:30 AM
V.T.E.C.
Aug 12, 2008 08:20 AM
TypeRvtec18
Jan 21, 2003 08:19 PM
