Transmission & Drivetrain Gearboxes, Differentials, Clutches
slipping..!
Old Feb 9, 2009 | 01:46 PM
japanRooster's Avatar
Default slipping..!
hey guys. i'm new to this forum. i currently drive a 95 accord with an h22a jdm motor/tranny. i recently replaced the entire clutch kit, flywheel, and slave cylinder. after driving for maybe an hour or slow, the clutch began slipping...it's weird though...even with this new setup, i get this problem!! i've inspected for leaks in the lines from the slave to the master and yet nothing... what should i do? please help. thanks!
Old Feb 15, 2009 | 02:57 PM
Mindgamez's Avatar
Default Re: slipping..!
Its your syncro Springs. There gone so the hub slips out of gear cause it has noting to grab onto. Which ever gear is slipping than you need to replace that spring. If its all your gears than you got a messed up tranny. Or you somehow messes up aling your clutch.
alaskanlue
Jul 20, 2009 09:30 PM
dephtone
Sep 11, 2007 04:48 PM
h22silvia
Aug 18, 2006 03:46 PM
herbalist
Mar 25, 2005 07:59 PM
airman clutch
Mar 26, 2002 06:37 AM
