Transmission & Drivetrain Gearboxes, Differentials, Clutches
can't shift problem
Old Jan 17, 2009 | 07:09 PM
flatblack-h22's Avatar
Default can't shift problem
for some apparent reason, i am having some trouble shifting gears with the car on. while the car is off, i can shift fine and go through all of the gears. if it does go into gear the car would jerk and stall out as it was left in gear, so i am assuming the clutch is not engaging/disengaging. i tried bleeding the slave cylinder also and it the same outcome. it appear to be any visible leak that i can spot. the slave cylinder moves when you press and depress on it as well.
Old Jan 17, 2009 | 07:24 PM
RyanA's Avatar
Default Re: can't shift problem
Unfortunately, that's a sign of either a bad master/slave or a worn out clutch. See if you can feel if the slave is getting full travel while someone slowly cycles the pedal. If you are, plan on a clutch.
Old Jan 18, 2009 | 05:12 AM
beastsohc's Avatar
that happend to me. for me the prob was my clutch disk. one of the srings on the disk broke.
99hondadx
Feb 10, 2017 05:35 AM
jdm_phunk
Feb 27, 2011 05:17 PM
dumpedeg6
May 5, 2005 10:20 AM
ludelvr
Sep 12, 2003 04:20 AM
del_parker
Sep 1, 2003 07:17 PM
