Transmission & Drivetrain Gearboxes, Differentials, Clutches
Dropping the engine with out a cherry picker
Old Dec 27, 2008 | 06:26 PM
spens 91 Ef's Avatar
Icon2 Dropping the engine with out a cherry picker
i need some ideas on how to drop my engine out of my car with out a cherry picker its a 91 honda civic hatch, i need to put a new clutch and i need my engine out. i have jack stands. also how would i put it back in
Old Dec 27, 2008 | 07:08 PM
Default Re: Dropping the engine with out a cherry picker
Old Dec 27, 2008 | 07:35 PM
arc_55's Avatar
you do not need to remove your engine to do the clutch. You can do it with the engine in the car, by dropping the tranmission and supporting under the oil pan with a jack and peice of wood.
Old Jan 3, 2009 | 02:07 AM
stealth50k's Avatar
Put a jack under the oil pan with a piece of wood on it for cushion then you use a hydraulic floor jack to hold the bottom of the tranny. Then have someone hold the tranny above and have someone turn the screw to let the pressure out of the floor jack. Slide the tranny under the passenger wheel base if you want to go that far. Make sure your car is jacked up enough.
Old Jan 3, 2009 | 02:10 AM
425_Booster's Avatar
Def. easier to remove the tranny, rather than the whole motor. YES!
Megaton22
Nov 8, 2016 10:24 AM
qazaq
Jan 23, 2009 05:01 PM
brodyl05
Mar 25, 2007 06:18 AM
alupso
24
Jan 24, 2006 12:08 PM
jordanb1
Jul 18, 2005 09:45 AM
