Transmission & Drivetrain Gearboxes, Differentials, Clutches
Question about B-series Flywheels
Old 01-23-2009, 12:00 AM
92redsihatch's Avatar
Default Question about B-series Flywheels
I'm about to change my clutch in my hydro GSR. i want to get another stock flywheel and have it resurfaced b4 starting on my clutch. will an LS flywheel be the same as the GSR?
thanks ahead of time HT
Old 01-23-2009, 12:02 AM
stealth50k's Avatar
Default Re: Question about B-series Flywheels
All b series flywheels are the same except the type r one which is a few pounds lighter. You should go aftermarket if your going to spend around 100 bux.
Old 01-23-2009, 12:03 AM
i was just gonna borrw my cousins ls one and have it prepped b4 starting to work on it
Old 01-23-2009, 09:43 AM
what type of flywheel would be good if i plan on boosting the car down the road?
Old 01-23-2009, 09:45 AM
Rheg6's Avatar
dont resurface .. if too much is taken off you will have clutch slipping and ur going to have to take apart the whole tranny out aagain .. mind as well do it right the first time
Old 01-23-2009, 09:51 AM
so what are you suggesting?
Old 01-23-2009, 10:39 AM
RyanA's Avatar
I'm not a fan of resurfacing the flywheel, either. If you DO resurface, make sure to put the appropriate flywheel shim in to space the contact surface back to factory specs. If you want a budget flywheel, a brand new OEM type on Ebay or at the parts store is around 60 bucks. You can get a chromoly flywheel on Ebay for a little over 100 bucks. I personally like one around 12 lbs (not a fan of really light ones as they seem to affect the way the clutch engagement feels) and made from chromoly instead of aluminum.
Ryan
Old 01-23-2009, 11:17 AM
ok, so since i dont have the money for a new flywheel, should i just pull the old clutch off and put the new one on? w/out resurfacing the flywheel?
Old 01-23-2009, 03:04 PM
bump, help?
Old 01-24-2009, 04:37 AM
RyanA's Avatar
Just depends what your flywheel looks like. If it looks OK and is not all hot spotted, you can reuse it. If it is hot spotted at all, just save up and buy a new flywheel for 60 bucks for the peace of mind.
Old 01-25-2009, 09:39 PM
Soichiro's way@MF's Avatar
actually.. . LS flywheels are the heaviest at around 18lbs. 96+gsr's have the same 16lb flywheel as b16's and are stamped with a PR3 on the back. Type R's being the lightest at approx. 14 lbs.
Old 01-26-2009, 04:06 AM
what about 94-95 gsr's?
Old 08-30-2016, 02:30 PM
pr40574's Avatar
How can I identify which flywheel is from what engine?
Old 08-30-2016, 04:20 PM
FlewByU352's Avatar
When you resurface a flywheel, you take the same amount off the pressure plate mounting surface... if whoever did your flywheel didn't do this, they shouldn't be paid.
Old 08-31-2016, 01:05 PM
BrakeExpert's Avatar
I'd also throw out a lightweight flywheel. Running a fidanza 7.5lb was a nice improvement and with an exedy stage 1 clutch (which is basically OEM) there was no harder engagement than stock. So if you're not racing it hard, there is no change from stock engagement but it revs just a little faster. Worth it for under 200$ for the clutch, flywheel and pressureplate shipped.
Old 09-05-2016, 08:40 PM
scrubdakiller80's Avatar
Have any of you guys seen broken flywheel bolts?
93_delsol
10-28-2010 04:58 AM
ekjay
09-09-2006 01:30 PM
eg-ed
08-10-2006 10:03 PM
cornhusker
03-05-2004 09:18 AM
mycvc8u2
01-08-2003 09:57 AM
Quick Reply: Question about B-series Flywheels
