transmission code and gearing education (civic 92-2000)
i have 2 transmissions. both are labeled as s20/p20. the difference is the CX(d15b8) transmission is labeled j8f, and the si(d16z6) transmission is labled y4b. i see no a000 or b000 on the transmissions. questioning gearing and other options for later.
Re: transmission code and gearing education (civic 92-2000)
There is a small circle cast in the main case by the fill plug about the size of a penny. In the circle it will be cast with P20/A00 for the 92-95 CX/VX or DX/LX with 35mm diff bearings. The EX/Si will be cast P20/B00 with 40mm diff bearings. There are 3 different Gear ratios for the USDM 92-95 S20 transmission. CX/VX - DX/LX - and EX/Si. The J8F CX has the longest ratio with a 3.25 FD and the Y4B Si has the shortest 4.25 FD.
thankyou. i was looking at you guys transmissions about a week ago. just picked up a complete swap and was questioning gearing for autocross.
do you guys have any experience with the phantom grip installed and advantages over an lsd other than the price. the biggest question is do they work?
rebuld. syncrotech can hook you up with a good rebuilt. your trans is near the same as a dx. so it may be cheaper just to swap in a used dx trans, as they are a dime a dozen.
Okay, to revisit this topic, i now have a P20 b000 transmission with a 24e lsd. i was looking at different fluids and questioned if the lsd required a bit thicker fluid.
D Tranny Guru
i looked it up in my hatnes 84 to 91 civic manual. didnt give an exact capacity. i put 2 quarts sae 10w30 royal purple.
the trans seems buttery smooth, 4th gear isnt even broke in yet.
D Tranny Guru
What do you mean 4th gear isn't broke in yet?
as far as the barney junk, in comparison, royal purple has the most Ppm of zink additive than any other Sae motor oil. Not even the moto guys have that high of a concentration. the only ones that do have this is thicker diesel oils like rotella from shell. this is because the rotational assembly just needs the oil to stick to more and for longer for protection. this is why, as well, there was a big changeover in mtf, oil, and other petroleum products with zink additives in 1974, 1986, and 1995.
what is the problem with the oil in my transmission?
hold the phone...i'm just about to put my tranny back in and was going to run to honda for some mtf and maybe grab some syncromesh to mix in with it...you're saying i can use the bottle of 10w30 motor oil i have and it'll be just as good?
The car can no longer be considered a DD lol...its a turbo-d circuit car
I sometimes do gm syncromesh mixed with honda mtf or just straight mtf
TomCat39
Transmission & Drivetrain
10-18-2016 08:57 AM
hayden55
06-23-2016 08:12 PM
tvrsir
07-24-2004 02:15 AM
