HELP! How to remove this?
We are trying to replace my broken Tranny of 2001 Honda Accord Coupe EX 4 cyc. Tranny is already dislodged from the engine. Just this tranny support that we could not remove. Pls. help. Pics below.
With the jack stand under the engine remove all the bolts from the subframe and take the two 19mm bolts out from the radius arm that goes to the pass side lower control arm then pull it down words the driver side and let it hang then pull out the trans you can leave the two 19mm bolts on the driver side to hold the subframe up.
arielb1
Oct 31, 2008 12:03 PM
0ptimus prime
Jul 17, 2004 11:17 PM
SuperDuude
10
Jul 1, 2004 09:24 AM
