ATS lsd vss
ATS lsd vss
My speed is not working since i have found out that with the installation of an ATS LSD a new speed gear is required for the sensor.
I have found one with the following measurements Diameter 18.8 mm, thickness 10mm ad 22 teeth
The stock speed gear measured at diameter 22.75mm, thickness 10mm and 20 teeth
Also the gears teeth have different direction as shown in pic
Have anyone came across the spped gear for the cusco, ats, kaaz lsd and what are the dimension
drift2004
12-17-2007 10:46 AM
n1_egsex
08-29-2007 02:44 AM
