Transmission & Drivetrain Gearboxes, Differentials, Clutches
tranny or diff problem help!
Old Aug 2, 2011 | 03:10 PM
jdm inc's Avatar
Default tranny or diff problem help!
I been on this diff for 2 seasons almost. It is a oem lsd gsr tranny. When i turn the car to the right or left really hard it just wants to kick the wheels back to going straight. it gets really hard to turn when u are going either left or right.
Could this be cause the diff is bad? What could be the problem?
Thank you!
Old Aug 2, 2011 | 03:30 PM
jdm inc's Avatar
Default Re: tranny or diff problem help!
o forgot to add when i jack it up and turn the wheels both wheels still turn.
Old Aug 2, 2011 | 04:52 PM
94EG8's Avatar
Seagull Management
Sometimes the OEM viscous LSDs will overheat and essentially turn into a spool. At that point it needs to be replaced. The bad thing is the GS-R/SiR-G trannys with an OEM LSD have a different bolt pattern for the ring gear so you have to swap out the final drive if you want to run an aftermarket or OEM Type R LSD.
Old Aug 2, 2011 | 04:59 PM
jdm inc's Avatar
thank you! for the info I think thats what might of happen!
Old Aug 2, 2011 | 05:41 PM
jdm inc's Avatar
and it does feel like a spool in there!
been looking into a quaife now will also have to find a final drive.
thanks for the info.
Old Aug 3, 2011 | 07:46 AM
Gearspeed-Performance's Avatar
They also break at the neck internally and have a variety of issues. Good excuse to get a final drive along with your new LSD!
Old Aug 3, 2011 | 01:48 PM
jdm inc's Avatar
if i change out lsd and ring gear do i have to change out the final drive also to match it?
thank you.
Old Aug 3, 2011 | 02:21 PM
The ring gear is part of the final drive. When you hear final drive set it means ring gear and countershaft
So if you swap out the factory LSD for an aftermarket LSD..you will need to get a matching final drive set to go with the new LSD.
Old Aug 3, 2011 | 04:34 PM
jdm inc's Avatar
Ok thank you!
Old Aug 3, 2011 | 06:58 PM
jdm inc's Avatar
Could i take the ring gear off a stock gsr tranny and use it? or is the bolt pattern different still?
thanks!
Old Aug 4, 2011 | 06:03 AM
94EG8's Avatar
Seagull Management
thanks!
Yes, but you'll need the matching countershaft as well (ie the one out of the same transmission you're getting the ring gear from)
Old Aug 4, 2011 | 08:25 AM
Just snapped a few pics of a broken factory viscous type LSD from a JDM GSR we swapped out for a Quaife with a Gear-X 4.7 Final Drive yesterday. This breakage is typical...have seen about 5 of them this year.
Old Aug 4, 2011 | 02:05 PM
jdm inc's Avatar
ah ic! could u explain more on it turning into a spool? just curious about it, Ill post pics of mine up whenever i get it pulled out.
I think that part might be broken also it sounds like the axles pops in and out whenever i turn too.
could u pm me a quote on a quaife too please! thank you.
Old Aug 4, 2011 | 03:13 PM
civickiller's Avatar
ive seen a few lsd's break right there before, they suck. i hate how the ring gear is built into the lsd
Old Aug 5, 2011 | 02:50 PM
jdm inc's Avatar
im surprised mine held up this long. lol
Old Aug 7, 2011 | 05:21 PM
jdm inc's Avatar
TTT
Old Aug 8, 2011 | 09:38 PM
I will PM you some options
Old Aug 9, 2011 | 04:18 PM
jdm inc's Avatar
got the pm thanks a lot.
Old Aug 21, 2011 | 02:27 PM
jdm inc's Avatar
tore mine apart. yesterday come to find all the gears in it all had missing teeth.
do they sell rebuild kits for these?
I also just purchased a quaife ill be installing.
Old Aug 22, 2011 | 08:16 AM
PM'd you....got some I can spare!
Old Aug 22, 2011 | 02:34 PM
jdm inc's Avatar
nice!
Steeve_Civic
Mar 3, 2013 09:55 AM
.BigSexy
Mar 8, 2009 11:39 AM
JDMH22HATCH
Feb 2, 2009 11:40 AM
GreenR
Nov 25, 2002 07:35 PM
