kaaz lsd troubles
kaaz lsd troubles
okay so i just got a jdm gsr swap with b16 tranny from h-motors.Steve informed me that that particular tranny has a kaaz lsd in it when i called about fluid specs since the oem honda trans fluid was too thin. motor runs great no problems there. the tranny on the otherhand has been kind of a headache. my passenger side axle has poped out twice in the last 3 day's. this axle was the same axel i just bought for the previous tranny (gsr) 2 months ago when i had the stock ls motor. yes the axle is in all the way and from what i can see the clip on the end of the axle is still good. any help would be great cuz im tired of smelling GL5 burning. thanks
cliffs/
jdmgsr swap from hmotors
kaaz lsd b16 trans
pass. side axel pops out randomly
cliffs/
kaaz lsd b16 trans
Re: kaaz lsd troubles
bought a shitload of kaaz fluid lastime i got some. just waiting on it to get here. i was gonna try a new axle tonight just wanted to get some opinions before i got one.
swapped axle's and used oem honda axle clips axle stayed in for a whole day then poped out again im starting to think its the diff any other opinons?
sounds more of an alignment problem than something a diff would/could. was the kaaz install the only thing that was changed at the time? any suspension? also check tire pressure. if one side is real low it will pull.
