tps/map sensor issues
Old Aug 16, 2010 | 12:55 PM
90teg's Avatar
Default tps/map sensor issues
I am having an issue with my swap. Everything is in, it is a k24a2 using a 02-04 type-s harness with 02 throttle body and I am using a jdm type R ecu(I know I know no kpro). Check engine light code is for the map sensor but if I swap the plugs (the tps/map sensor plugs) it'll throw a tps sensor error code. How do I know what plug goes the right place? Can anyone tell me the code color on the tps plug and on the map sensor plug so I can know if it's either the tps that's bad or the map sensor. This is in a DC2.
Pataplomo
May 31, 2018 12:56 PM
Monstarrr*
Sep 3, 2010 08:26 PM
eg93LS
Jun 10, 2009 08:51 PM
92ehatch
16
Feb 19, 2007 11:41 PM
