VSS...
Old May 19, 2010 | 08:49 AM
Keo.'s Avatar
Default VSS...
Throwing a code on my car...It comes up intermittently(as in not all the time,aka stopping and starting again) as a VSS fault...My first guess is the vehicle speed sensor, but I'm guessing it has something to do with the transmission because the car will stall out if you take it out of gear coming to a stop and the CEL is on. If the CEL isn't on, the car runs fine.
I was also thinking maybe a faulty TPS, since it stalls out.
EDIT: VTEC will not engage if the CEL is on, and in some instances, the car will redline at 5500ish RPMs when the CEL is on.
Old May 19, 2010 | 01:57 PM
josh's ep3's Avatar
Function > Form
Default Re: VSS...
Hmm, you might get better responses in the K motor section. I will move this for you but I will leave a redirect.
Old May 24, 2010 | 08:14 PM
Keo.'s Avatar
Default Re: VSS...
Apparently not?
ferio252
May 8, 2008 10:35 AM
CompanyFlow
Acura TL, RL & ZDX
Oct 26, 2006 08:24 AM
Draggin99Si
Aug 18, 2003 08:36 AM
