k24/k20 head question
planning to get a k24 from a accord and swap a k20a2 head on but is it a direct bolt on, planning to swap into a integra, or should i just get a full k20a2, which one would be better,
Re: k24/k20 head question
you would want a tsx or a cr-v block.. the type s head is a not a direct bolt onto the accord block. that tsx and the cr-v is.
Moderator
k24a4 pistons will not work with a k20 head.
you will need to at minumum change the pistons out to allow for clearance of the head onto the block.
the a4 pistons have a FUNKY shape to them and the head will not sit on the block without contact to the head.
92hatchattack
Engine Machining & Assembly
09-01-2006 02:59 PM
