Help everybody Please
Old Aug 23, 2010 | 06:22 PM
djinnaroth's Avatar
Default Help everybody Please
Hello every body, i'm new to this forum and a noob
well first of all i have a honda accord coupe 2008 2.4
well, i used to own a Mercedes slk230 compressor, so it stopped working cause of the crank shaft got broken , and its so bloody expensive to change, so i said after 12 years of this car running perfectly its time for her to rest in peace , anyways let me get to the point
this car have a compressor Eaton m45 which is not mounted on the head or bolt on, it is mounted on the side , it have a belt that runs on from the engine so my question is can i use this compressor to my car?,cause as i know we cant install a turbo, cause the manifold thingy, and we cant play with the ecu, cause no cracked it yet.
I can work on custom fitting in the garage, so i can fit it in , but do i need to also tune the ecu so it can work? or it doesn't need any of this ? cause if it works i guess to should give the car some serious gains !! cause it starts spinning on 2500 rpm
what inspired me is that, several months ago i did a research about this and ive found out that a guy from Russia also have an Honda accord"TSX" 2.4 compressed, he managed to pump out 304hp, ive tried emailing him couple of times, but no use
http://www.cardomain.com/ride/3324261
all what ive found out he tuned his car Unichip but everything else was custom made
can you guys please guide me and help me if it is possible
thanks alot
djinnaroth
Aug 30, 2010 08:40 PM
katanamast279
Jun 11, 2009 08:40 PM
HNP
Honda Civic (2001 - 2005)
11
Jun 14, 2008 05:59 AM
carnz98gsr
May 10, 2008 11:01 AM
Flatland2D
May 19, 2006 05:40 PM
