k24/ k20 or k20
k24/ k20 or k20
which will be better with boost. Either way i go the motor will end up being built eventually. I plan on using a gt35r. and make around 500-600 hp on high boost at the track and around 250-375 on the street. *note this will be my daily driver with a/c and p/s(maybe)* what kind of numbers are you guys putting out on stock block and head? All advice will be greatlt appreciated.
Re: k24/ k20 or k20
My buddy made 513 on a stock K24a4 element motor.. If I were you Id just get a newer (06+) K24a2 TSX motor and boost that. You can make 500+hp easily, its just all about the tune! If your tryin to only get 250-300 you can do that all motor, and then put a little 100 shot on it and you'll have a 10-11 second car depending on elevation and what chassis your puttin it in. Either way you choose to go it'll be a fun car
Re: k24/ k20 or k20
That is a lot of power, period.
This holds true for almost every turbo setup, but since you are playing with stock engines (that AREN'T meant for boost) the tune is going to be what makes or breaks you.
I've seen K20A2/Z1 engines make well over 500whp on stock blocks. It all comes down to your setup, if you plan on making a ton of power like that, don't go cheap with your parts.
Re: k24/ k20 or k20
I made 615hp/451tq K24/K20 setup, click this link below for specs and videos...
https://www.k20tuned.com/xcart/pages.php?pageid=2
