Depin Injector clips..
Has anyone depined there injector clips to put the scion ones on?
I would love to see how its done, cutting/soldering is not an option.
Thanks!
Thanks!
Re: Depin Injector clips..
You really just push them on.. you don't have to cut anything. You only have to cut if you try to use the connector from the type S...
They don't fit in properly, but you can get them to work.
Really push on what??
Pics would help.
trying to depin the stock rsx-s harness right now with no luck(injector clips)
Pics would help.
i got it figured out thanks...
blue lock peice comes out, then 2 tabs you pull up that are hard to see need a good light then pull the wires out
6spd_EK posted info on this 2.5 years ago:
Originally Posted by 6spd_EK
ok if this pic doesn't help... then go buy RDX injectors & Scion clips LOL... it much easier to understand with the pieces in front of you. it took like 10min for Paul (runnerdown) to fit the scion connectors to the k-series pin connectors
left is stock - right was trimmed......you can see stock - is like 2/3's length on top side... & trimmed is like 1/2 length on top side
It's not hard, man. Just use an ice pick to pop the little white cover out of the inside. Get a needle and pry up the retaining prongs and pull the wires out the back. I didn't know how it worked either, but it took 10 minutes to figure it out.
roachsboosted16
12-06-2007 06:44 PM
turbotime
05-14-2006 02:33 PM
