k24 Build help needed
Old Mar 3, 2010 | 08:18 AM
Allmotor-R's Avatar
Default K24 bottom end
WHats the highest you can rev this motor ?? does all of them pretty the same or is there any difference planing to put a k20 head just need some info
tx for the input.
Old Mar 3, 2010 | 03:35 PM
seek167's Avatar
Default Re: k24 Build help needed
you seem to know all about k series motors in this thread.
https://honda-tech.com/forums/acura-integra-type-r-8/guys-k-swap-2720113/
why do you need other peoples advice on what to use?
Old Mar 4, 2010 | 08:50 PM
Allmotor-R's Avatar
https://honda-tech.com/forums/showthread.php?t=2720113
I know a lot but
I dont know it all!!
There is so much to learn!
Old Mar 7, 2010 | 03:16 PM
k20coupe's Avatar
I take mine to 8100 I have an a2 oil pump and on my head I run dual springs and stage 3 cams and I run a stock rbc if I didn't have all that stuff I'll take it to 7100
Old Mar 14, 2010 | 06:50 PM
Allmotor-R's Avatar
you made 306whp on stock rbc manifold not ported?
Old Apr 10, 2010 | 07:13 AM
onefstek's Avatar
Default Re: K24 bottom end
tx for the input.
Several things you need to look at when you want to rev the motor higher. Oil pump is one, and see at what rpm will start cavitating. Rods and rod bolts are another, and looking where the rod bolts will start streching. One other is why you are looking to rev it higher. Are you using a cam that will require you to rev it higher? Or you just doing it for the fun of it?
Old Apr 25, 2010 | 08:36 PM
EFvTeC's Avatar
I have a A2 oil pump on an A4 block But had my complete rotating assembly balanced and I am using a ITR K20a head...I rev mine safely to 8900RPM with no problems but if you dont make power up that high its pointless.... So I stopped making power at 7900RPM So I say if you have everything balanced and an A2 pump try it out on a couple pulls on the dyno and stop your rev at whatever you stop making power....
Old May 6, 2010 | 08:12 AM
AddictsRacing's Avatar
If you have an a2 oil pump with some supporting modifications, you should be fine up to 9k. But it all depends on where you stop making power, to be honest, there is no point in revving to 9k if you stop making power ~8k rpm, as the others have said.
leadfoottyler
Jan 14, 2013 09:17 PM
ASHLEY_DLTN
Honda Civic (2001 - 2005)
Oct 20, 2009 12:28 PM
crxnightrider
Acura TL, RL & ZDX
Oct 28, 2008 09:34 AM
BigC-ivic
Jul 19, 2004 04:52 PM
