k24 block issue
Old Sep 7, 2010 | 05:01 PM
civic-r11's Avatar
Default k24 block issue
I have a crv block that I am wanting to build up.. But I am lost on how to modify the oil pump from a k20 to work on it.. And is 12:5:1 really ok for the street? It will be n a daily driver... So yeah... Would it really be ok..
Old Sep 8, 2010 | 07:44 AM
HarosGSRek's Avatar
Default Re: k24 block issue
you might have to register...you want to anyways
http://www.k20a.org/forum/showpost.p...5&postcount=12
Old Sep 16, 2010 | 11:00 AM
Seek Speed Shop's Avatar
it is quite simple.
mock the A2 pump up against your block. section it out with a marker where the pump interferes with the block/girdle. Take a grinder/file/cutting wheel and start going to town. Dont worry if it seems like you have to cut away a lot. You do. Tape up all orifices also, dont want any metal getting in your oil pump. Having compressed air helps, Blow away all shavings/aluminum dust.
make sure you get a new chain when you do this as well, it is work doing.
Old Sep 16, 2010 | 07:42 PM
90ED7's Avatar
You have a k24a1 ?
Old Sep 19, 2010 | 06:45 AM
onefstek's Avatar
If you have a CRV (k24a1) you will not have to grind the pump. It bolts straight on, no mod required.
Stefan
nighttrain33
Oct 3, 2006 07:30 PM
BoostedEgHatchFl
Oct 26, 2005 06:10 PM
Odiedogcx
Sep 20, 2004 01:42 AM
