Block Rebuild, Help Please
Old Jan 4, 2010 | 03:00 PM
silentkiller120's Avatar
New User
Icon3 Block Rebuild, Help Please
ok, hello to everyone, I am a new user on this site but I got a serious problem with my cylinder block.
First one of my spark plugs seized up and strip the threads completly out the head. I threaded it and put in a insert pretty easy but once I had the head off I noticed mythe cylinder head bolts were loose......
Getting to the point, I put heli coils in striped block. When I put everything back together I striped another one, so I took everything off and did all of them....
Know I have one bolt that the heli coil did not hold up. Its acting as if the ct loil itself is spenning but yet I can not loosin it or tightin it for that matter...
Im sure I can get it out but my question is can I put time inserts in there instead seeing as every kit I have found has the same drill bit hole size but the threader is diffrent style.........I cant thread over new threads and would rather use time serts......any ideas would help alot.
Heres my spes:
bolt size 11m 1.5 ,
drill 29/69
acura integra LS automatic 1.8v 4 cylinder
I belive what I need is a kit that has a bigger drill bit size so the threads can be clean when im done.... please help if you can
gooblinn258
Apr 22, 2014 08:50 AM
jyracer
Dec 29, 2009 10:02 AM
jmoorepghpa
Classic Hondas
Jan 13, 2009 10:59 PM
pip9
Jun 15, 2004 03:58 PM
Sonny
Nov 25, 2002 08:30 AM
