k24 miss/studder
Old Aug 10, 2009 | 05:07 PM
chad's Avatar
Moderator
Default k24 miss/studder
k24
tsx pistons
k20z3 head
k20z3 cams
compression is 225-230-230-230
valves are set at .08 on intake and .09 on exhaust yes i know alittle tight
fuel pressure 65at idle
310 injectors
under load there is a miss or studder. car keeps accelerating....air fuels drop alittle but not much.
have changed:
coil packs
spark plugs
drained fuel tank put new gas in
new fuel pump
new fuel pressure regulator
reinstalled tune on kpro
all grounds
data log:
injector duty cycle 80% on kpro
injector opening up to 15ms (is that my problem?)
also data logged
battery volt 14.2
eld amps 3.2
eld volt 19
are my injectors too small??
i'm making 243 at 7800 and still climbing...but that is where rev limiter is set.
gonna move the ecu to see if it is getting a weird vibration off the cage.
thanks for the help
retune on dyno....NO MISS....on track first session....MISS returns!!! grrrrrr....anyone??
chad
Old Aug 10, 2009 | 06:51 PM
cjordan's Avatar
Default Re: k24 miss/studder
In to see the result of this since I helped trouble shoot it at the track to no avail... I am almost wondering if wrapping the ECU in dynamat would help with the vibration...
dkennedy1
May 13, 2017 04:38 PM
DAtegLs
Aug 2, 2010 08:57 PM
corked1260
14
Jan 28, 2008 03:13 PM
Ruben19
Jan 29, 2006 04:31 PM
Leo95SE
Jun 24, 2002 01:03 PM
