speedo cable help
Old Aug 19, 2009 | 11:20 PM
dumpedhard's Avatar
Default speedo cable help
ive got a Eg hatch with a k20a3 swapped in right now. do i use the stock ef speedo cable or what? speedo isnt registering
Old Aug 20, 2009 | 11:40 AM
allmotorek4's Avatar
Default Re: speedo cable help
eg vss are drive by wire.. why would you wanna swap an ef drive by cable one in .. you can use the stock k20 vss(drive by wire just like the eg ones) with your eg cluthers just gonna be reading a little off. and plus if you add'd an cable vss it still wouldn't work the gear on the vss are not the same and plus the ecu need to read your vss or else your gonna have a c/e light and vtec wont happend.... ^ is that you jason?
f@sth@tch89
Transmission & Drivetrain
Jan 25, 2011 08:10 AM
96johnson
Jun 3, 2010 02:56 PM
killerpenguin21
Apr 30, 2010 08:27 PM
PnkRokCountryboy
Aug 2, 2007 12:02 PM
