K20/eg state ref ?
Hopefully someone can lead me in the right direction, I already have the swap done. Its a usdm k20a2, a factory exhaust manifold, and recently swapped ALL the wiring from the rsx. The ? is... does anyone have any new info for the possible gas tank swap? The pics from the swap that r-crew had done are so old they don't show on any of the forums. Does anyone have pics or is there an easier way (different gas tank that might still work)?
I know all the ref is doing right now is visuals, i'm going to try and get down there this week and hopefully get a stamp, but in the long run without the evap stuff hooked up right (and with a stamp) i'll still have to get a hook-up on the smog. Those people might not always be available and to know if its done right you can take yor car anywhere (and not towing it)
Thanks in advance for any help!
it is possible to bar a k20a2 in a eg as i have done one the problem i ran into first is they dont allow kpro next you must retain the fuel less return system the rsx has the only way i was able to achieve this was to place the entire rsx gas tank inside the car for visuals and make it appear to work since all they do is visuals
Wazup
Mar 14, 2007 04:46 PM
