K series axles
Old 08-31-2009, 08:38 AM
aemintgsr's Avatar
Default K series axles
Ok so i slapped on my k24 with a 05 type S tranny on my teggy and i had bought the K Swap budget axles from HR and the pass. side axle is like 1.5 in longer and the driver side doesnt go in all the way
Is there any stock axles like from an EP3 or RSX that i can test fit or do they have to be like Hasport k swap axles??
Old 08-31-2009, 01:05 PM
aemintgsr's Avatar
Default Re: K series axles
Anyone?!
Old 08-31-2009, 01:35 PM
dschybrid's Avatar
The budget axles are for EG/DC swaps. The EP3 axles are going to be the exact same length.
What is the overall measurement of the axle once it has been compressed?
Old 09-01-2009, 12:53 PM
aemintgsr's Avatar
Ok i got the driver side in there and it fits perfect, but for the pass. side i talked to Hybrid-Racing and they said i needed a K20A2 Intermediate Shaft for it to work... Will it bolt on to my K24A2 block if i get one??
Old 09-02-2009, 08:33 AM
dschybrid's Avatar
Yes, you will need a K20 half shaft as the K24 shafts are a bit longer.
That's going to solve your issue with the axle.
Old 09-02-2009, 12:07 PM
aemintgsr's Avatar
Kool Thanks
Old 09-02-2009, 02:09 PM
BUILTLS/V's Avatar
Will the half shaft fit on 02 si block
Old 09-03-2009, 07:09 AM
dschybrid's Avatar
Unless you want to run custom length axles, there is no point in running the K24 half shaft.
It's possible that it would fit, however not really relevant as the swap axles don't work with them.
Old 09-03-2009, 04:31 PM
BUILTLS/V's Avatar
soooooo a k20a2 halfshaft on a k20a3 with ep3 axles in a teggy will work? My axles are short i need help thanks.
Old 09-04-2009, 07:24 AM
aemintgsr's Avatar
Damn mine are too long, yours are short!! Soo it has to be a K20A2 for sure???
Old 09-04-2009, 08:57 AM
dschybrid's Avatar
Half shaft Part numbers...
Acura:
44500-SCV-A00 is the Acura Pt# for the 02-06 RSX K20A2 & K20A3
44500-SDA-A00 is the Acura Pt# for the 04-08 TSX K24A2
Honda:
44500-SCV-A00 02-05 Civic Si EP3 K20A3
44500-SDA-A00 03-06 Honda Accord K24A4
44500-SCV-A10 02-05 Honda CRV K24A1
Hopefully this clear things up. Any 2.0l half shaft will work with either motor to get idea axle length.
What mounts and axles do you have BUILTLS/V?
Old 09-04-2009, 01:13 PM
BUILTLS/V's Avatar
ep3 axles with hasport mounts.. so ur sayin it won't? is the half shaft longer?, so when u put on the pass. axle will fit all the way?
Old 09-04-2009, 01:58 PM
BUILTLS/V's Avatar
For real.
Old 09-08-2009, 09:32 AM
dschybrid's Avatar
Hasport mounts in an EG with EP3 axles must use the K20A/K20A2/K20A3 half shaft.
If your axles aren't fitting, you've got the wrong ones.
Old 09-08-2009, 11:37 AM
BUILTLS/V's Avatar
these were ep3 replacement axles ordered from u guys at hybrid racing. are any other options?
Old 09-09-2009, 06:43 AM
aemintgsr's Avatar
I got a K20A2 halfshaft and they fit perfect now, thanks for the help everyone.
Cap'N Chronic
05-24-2011 06:08 PM
ak_teg92
03-22-2007 02:27 PM
bipedbear
04-04-2006 12:33 PM
McDade
09-01-2003 07:49 AM
Quick Reply: K series axles
