PDA
View Full Version : Classic Hondas
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. Multiple distributor failures
  2. My 1983 Civic Wagon
  3. 1984 Honda Crx DX Overheating issue
  4. O/t not relly tech Resto builds
  5. Gen II head on a Gen III 1500?
  6. 80 Accord vs 83 Civic fuel tank
  7. Y8 into a 1986 crx
  8. 1983 civic B18C
  9. 83' civic wagon front suspension issue
  10. Do you think my alternator is bad?
  11. Where to buy window moldings/seals?
  12. new to forum. 1982 Honda civic wagon. need ideas
  13. 3G Civic/1G CRX Gas Tanks
  14. 82 Civic 1.5L Head Gasket Issues
  15. wiring help
  16. 86 Honda Accord
  17. 82 civic wiring diagram
  18. suspension swap
  19. K swap in 87' civic hb si?
  20. 85 crx si vtec swap help
  21. 1987 Honda Civic Si fuses
  22. 1985 Accord Hatchback 5-speed
  23. 1980 Civic 1500DX. Last ran 10 years ago. Now runs everyday with MR-5's
  24. Wtb Need interior for 74 cvcc
  25. 87 Prelude Speedometer works, but only when parking brake is engaged
  26. 1982 honda prelude turn signal relay location
  27. 87 CRX-HF Airconditioning Issue
  28. 1987 Accord DX 2bbl runs rough at idle when hot
  29. 82 Civic Wagon sir
  30. Honda Civic Resto - 1981
  31. 1985 Civic Wagon Opinions
  32. Looking to buy, opinions please!
  33. 1984 Nighthawk 650SC Clutch and Other Issues
  34. 82 civic d15 swap in progress
  35. 1986 Civic AH revival... Batt dead - No radio & horn
  36. Need Help! Identify the Rare / Optional Parts on this 1G CRX
  37. 71 N600
  38. 82 EK1 MODS?
  39. 82 civic head issues
  40. Lovingly restored Honda n600's
  41. b15b2???
  42. New to forum, 1982 Civic CVCC Wagon Build/Restore
  43. Torsion Bar Help
  44. Need questions answered on an '87 RT4WD
  45. 87 Civic Si
  46. My '86 Civic Si
  47. 84 Honda Civic Wagovan A/C compressor
  48. 82 Civic DX
  49. 1988 Accord ignition issues need help
  50. 1986 honda civic si, restart issue after it gets hot
  51. first gen preludes...anything to look out for?
  52. 1984 Honda Civic Wagovan Exhaust
  53. What brand fuel injector
  54. Sputter after running dry /86 civic si
  55. Possible 76 CVCC Purchase
  56. Crank sensor
  57. NEED HELP ASAP!
  58. Source For Parking Light Lens, 1982 Civic?
  59. 86 Honda Civic Si....Idle Issues :(
  60. 89 honda accord lxi oil light acting up
  61. NEED HELP!
  62. for anyone who thinks single cams are slow.....
  63. CRX Grille
  64. Timing belt tensioner
  65. 85 civic wagon, huge studder off idle
  66. 87 CRX Trouble with acceleration
  67. MSD 6A CD box on a 2cylinder Hond N600
  68. 1987 Civic sedan smog problem
  69. '83 Accord. Best way to get it to sellable condition?
  70. '87 Civic - "rebuilt" Trans - Mystery shifts?
  71. a few pieces of the interior thats going in my 86 Accord Hatchback
  72. Saw this in a local junkyard
  73. Carburetor rebuild or replace??
  74. 85 Accord idle issue : (
  75. 1989 Honda accord LX alignment
  76. Auto Tranny "Issues"?
  77. Rebuilding 1986 honda civic si ew4
  78. Boot lid wanted 65 S600, Michelago NSW
  79. Weber Install - Cut Throttle Cable End?
  80. Block Off Plates for '87 1.5L Devac
  81. 87 prelude carbed idle issue
  82. 1989 Honda Accord DX 2 BBL Question about hose
  83. first gen crx with second gen front parts?
  84. transaxle swap on stock 86 Crx si
  85. in need of some advice
  86. 83 civic 1500 sedan rev problems
  87. My Dream 85 Accord -- Is it Possible?
  88. New brake issue after installing new parts
  89. MUGEN SCCA CRX replica - awesome build
  90. CVCC Valve Spring Compressor
  91. 1988 accord idle issue
  92. 85 VT250F
  93. Aluminum flywheel for A20A3
  94. 3rd gen accord trim replacement?
  95. Clutch cable adjuster at the end. 88 accord HB
  96. Are split axle boots ok to use
  97. Swapped 79 Cvcc (B-series inside)
  98. 88 Honda accord stalling!!please help!!
  99. Honda S600 AS285-1004838 Restoration
  100. my 79 civic cvcc
  101. So, I just bought an '87 Accord LX-i.....
  102. '86 crx si replacement tps
  103. 1986 honda accord carburated
  104. 1983 Civic wagon 5 speed
  105. very first project.. 71 n600
  106. Not a Hond Guy
  107. Getting my first Honda back (1981 Civic 1500)
  108. 3rd gen accord lca bushing ?PH
  109. 86 CRX stock head swap?
  110. 1989 Honda Accord Ignition Timing
  111. '89 Honda Accord won't start!
  112. 1981 Civic 4 Door (48k)
  113. Need Advice for MY First Car
  114. 1987 crx si
  115. is this accord worth the asking price and should I resell
  116. Timing covers
  117. 1983 civic 1500 S value???
  118. 86 Honda WagonVan
  119. Newbie - Fan Timer Help
  120. Need Help! 1984 Civic Wagon
  121. Z600 / N600 Part Info Requests
  122. 1989 Honda Accord Hatchback DX
  123. 1980 Accord dies
  124. massive vacuum delete??? 1987 honda
  125. S600 Engine
  126. 1980 Honda Civic Brake Question
  127. 86 CRX Si
  128. pickup a new toy.. 71 n600
  129. Honda Civic 1984 1.5i GT engine swap help please!
  130. Gabriel Ultra struts
  131. what is the mpg of an 87 civic hatch with 1.3liters?
  132. My 1983 2gen Civic
  133. 89 Honda Accord LXI
  134. 82 Accord Rear Brake Problem
  135. Dispute about 85 CRX Si swap ( opinions plz )
  136. '87 Legend Coupe - Door Lock Cylinder Removal
  137. Can this swap be done? 85 CRX SI
  138. wtb front windshield
  139. 85 CRX Si swap help (whats the best swap for it?)
  140. 83 civic ignition control problem
  141. 87 honda civic alternator?
  142. 1988 honda accord lxi main relay???
  143. 1980 Civic 1500cc swap?
  144. 85 Honda Civic 1300 cold start high idle questions
  145. 1987 frequent bogging *please help*
  146. Quick question about the RT4WD wagons.
  147. 1986 honda civic si main relay repair
  148. Blown head gasket
  149. Need Parts?
  150. need carb help with a 1987 civic..
  151. Restoring 1978 Honda Civic 4 door hatch
  152. Back in the scene
  153. new project coming soon
  154. Pic Request: 1st Gen and 2nd Gen OEM Floor Mats
  155. 86 si civic booster removal
  156. NEED HELP FAST!!!
  157. 86 Wagovan 4x4 5 speed - Engine swap options? Is it worth it?
  158. 1st gen CRX D16A1 swap
  159. 83 honda carb.
  160. '77 CVCC w/ Hondamatic
  161. 85 crx mugen kit?
  162. 1986 Honda Accord stalls or won't restart.
  163. weber swap ?s
  164. '82 Keihin 3 Bbl. Carb kit or rebuild recommendations
  165. 86 CRX Si Project car
  166. clutch cable length/removal
  167. 1982 Prelude will barely start, Help!
  168. 1971 honda AN600 resto
  169. The famous PGM-FI on
  170. 1st gen Honda Accord
  171. What can i do to make my D13A1 Faster
  172. Tech Question: High Idle Speed issues (1984 Civ s1500)
  173. Honda 600 Facebook Group
  174. Check Engine Light at High Speeds 91 civic
  175. 1991 Civic rt4wd Dohc ZC Swap! need help
  176. 1970 Honda N600 - Mid Engine D15B Build Thread
  177. 87 civic si FITV / idle control valve trouble
  178. 2nd Gen Civic Devac write-up???
  179. My 1978 honda civic restore/upgrade
  180. honda city, anyone thought of bringing one over?
  181. 1982 civic wagon Need help!
  182. My 83 Accord
  183. 89 accord timing help needed!
  184. New to me 83 Civic
  185. Aussie S600 convertible
  186. Need some 1983 Honda Civic "S" Help!
  187. 1987 CVCC Civic No Start
  188. 1986 Civic Si Exhaust Studs
  189. 84-87 crx h2b swap
  190. 87 CRX HF A/C quiestion
  191. engine swap
  192. Adjusting cruise control
  193. 82 accord seats
  194. 81 Prelude Flooding
  195. Gen II Civic measurement needed
  196. My Gen II Civics...
  197. Help With '86 Civic Si Swap
  198. EW1-HF Main/Rod Bearing Size Issues
  199. Looking for some weber carb help/information
  200. 83 Accord Help
  201. 77 CVCC wont stop flooding itself at idle
  202. 1988 Honda Acty - Where to find info?
  203. 1983 civic wagon bogging issue
  204. 1983 Civic DX 1500 5-Speed
  205. 1984 CRX 1300 5 speed - Need some help
  206. 1981 accord secondary pump?
  207. My '79 Coupe
  208. '87 Civic Hatch - Indicator Relay
  209. 20 S800 Meeting in Germany May 2013
  210. 84 CRX Carb Replacement
  211. Help w/blower motor replacement please
  212. Please Help! 1986 CRX HF & O2 Sensor
  213. 1974 Honda Civic 1200 on bike carbs
  214. Proud new CVCC owner...
  215. 86 civic si misfire power on hills
  216. German S-Car Meeting April 2013
  217. Junkyard Finds, Oklahoma
  218. classic honda steelies, i think 70's cvcc...
  219. Unplugged ECU And Battery now car wont run.
  220. 87 civic hatch a/c problem?
  221. 83 Honda Accord questions
  222. help w/ 87 civic hatch servic box code
  223. Oil pan
  224. Found an all original 79 civic hatch, value?
  225. Toms 74 Civic restoration
  226. side draft carbs for ek1 ?
  227. 88 Accord Lxi project, New to tuning
  228. rough idle 1987 honda accord
  229. 81 civic 1300 trans question
  230. $1700 to fix, save or sell?
  231. 1st-gen Civic / Accord owners...
  232. What's the best route to...
  233. 89 accord sporadic idle
  234. D16 idle issues please help lol
  235. Question on 1983 Civic interior fuse box panel
  236. 1977 Civic CVCC hesitation during mid-range acceleration
  237. 87 Civic Si Problems
  238. Any Other Radiators Fit the 81 1500DX?
  239. Is this 1983 Accord worth anything?
  240. 86 crx hf
  241. 1985 Civic S1500 (B16 swap in progress)
  242. How to convert to obd0 or obd1?! 1.5 SOHC
  243. 86 CRX w/ swap Swap Bogging, Backfiring, No Power?
  244. '85 1.5 12V PGMFI - Going turbo, need management advise
  245. 87 civic DX rusted rocker, advice
  246. 78 Honda Civic - First restoration project
  247. 88 honda accord lxi speed sensor removal?
  248. 1981 Civic cvcc 5spd Wagon
  249. A/C pull help on 1987 Honda Civic
  250. Found a Honda 600 junkyard
