PDA
View Full Version : Classic Hondas
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. check engine light
  2. 3rd gen civic dx reliability questions
  3. Christmas Day
  4. New Combo Switch
  5. 1980 Civic 1500dx 5 speed
  6. California emissions vs. Federal emissions for distributor
  7. ???? Sudden high idle 87 accord 2.0 carburated
  8. Jackson Racing Widebody 79 Civic 1200 DOHC ZC
  9. My DOHC ZC 1979 Honda Civic
  10. 87 accord 2.0 2B carb. distributor assistance please.
  11. B20 swap into automatic 1993 Honda civic
  12. information
  13. Thermostat casing replacement / distr. In way advice please.
  14. How do i separate the engine and trans in a 1983 civic 1500 ?
  15. 1st gen civic swap
  16. Kansas City area - need someone who knows carbs
  17. 1988 Civic wheels....thoughts on value??
  18. Easy alternator replacement tip for 87 accord
  19. Engine failure, but not seized??
  20. Keihin VB
  21. irs swap on a 3rd gen civic
  22. KICK AND GO SCOOTER
  23. Question about 1989 Honda Accord LXi
  24. Cooling fans not coming on when temp is reached
  25. 1982 Civic Fuel Filter Location
  26. German S-Car Meeting 2018
  27. Thought I'd share this find...
  28. 2nd Honda, similar to first...
  29. Carb Devac a 1985 Honda CRX HF with CAL Emissions & A/C w/o Issues?
  30. 1st gen crx 1985 b series swap. Non si
  31. 2nd gen civic appraisal
  32. 87 civic sedan
  33. 86 civic dx d16a1 swap questions
  34. Starter for my 79 honda cvcc wagon??
  35. Troubleshooting 1987 Civic- Car is now stalled after running idle long time
  36. Racing Honda S800 in Germany
  37. 1986 civic si
  38. Help!
  39. Best Place For Parts?
  40. 1991 Beat engine problem
  41. 85 EW1 help. Go ahead and laugh
  42. 1986 Honda Accord Hatchback Not Starting
  43. 85 crx injectors not firing
  44. Texas 66 S600 Roadster
  45. 1983 Honda civic SEDAN 1500 Rare?
  46. Where to get Honda TN 360 engine
  47. 1984 CRX Turn Signal
  48. 2nd generation Honda questions
  49. rear bearings 1982 honda civic. Is there inner and outer bearings
  50. CVCC: 4spd vs 5spd
  51. old car
  52. Roof rack OEM Honda
  53. 1980 Honda Accord Ek1 Motor
  54. 89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
  55. 1972 Honda N600
  56. ‘82 headlight question
  57. 1983 Accord Idling issues.
  58. weber for 1989 honda prelude 2.0s
  59. What to do with mint 1982 Civic?
  60. 85 Accord. What to do with suspension.
  61. Exhaust diameter
  62. Fuel delivery issues?
  63. 1989 DX Accord Idling issues
  64. Second Generation Civic Vin #
  65. accord 88 mechanic
  66. battery indication
  67. Fuel pump relay
  68. 1982 civic won't stay on
  69. 86 sedan motor swap
  70. Headlight low beam one side
  71. New CV axle popped out - how screwed?
  72. 1967 S800 Coupe. Head Skimming.
  73. 1985 Civic cooling problems
  74. Battery terminal colors
  75. Honda Accord 1981 non cvcc D16 SWAP
  76. help on 84 accord b20a5 swap
  77. SHE'S ALIVE!!!
  78. 1980 civic with only 30k miles
  79. New on board
  80. Head bolts for an EM1 engine
  81. Diagnostic Electrical Issue: 1989 Accord LX OBD0
  82. Where can I find Brake Pads for my 1982 Honda Civic 1500DX?
  83. Rear bumper will not line up
  84. 85 civic rally car
  85. 1989 Accord Transmission installation trouble
  86. Windshield Rubber Seal
  87. ECM location in 1987 Prelude
  88. 86. 3rd gen virgin
  89. 83 stalls when put in gear, idles fine otherwise
  90. ticking lifter 1988 honda accord DX 2.0 Carb
  91. 1981 Honda Civic hatchback DX 5 speed
  92. Torque ratings for Clean 79 prelude 90k orgnl miles
  93. battery light
  94. rear hatch wont open
  95. 1982 Honda Accord Engine Swap
  96. '87 Civic Semi-Auto to Manual conversion
  97. 1985 honda civic wagon ew1 timing issues
  98. unexpected engine failure
  99. Trouble Identifying Engine Type Honda 1976
  100. vintage JDM in las vegas area
  101. 1978 cvcc hatchback build
  102. 1986 civic engine swap
  103. Engine suggestions for 3G Civic
  104. 1987 Civic starting/high idle issue
  105. 85 accord HB, sei engine swap
  106. 1987 CRX DX Wont Stay Running
  107. Supposedly rare 1984 crx need help
  108. EW1 Oil dipstick
  109. A20A3 throttle body size 1985-1987 Prelude Accord
  110. 1975 CVCC Wagon 5 speed project...
  111. 84 CRX clutch
  112. 83 Honda Ballade (Civic ? ) What should I do?
  113. STOLEN 1986 dx hatch in SF nov 17
  114. HELP Removing Starter 79 CVCC
  115. My '64 Honda S500 Restoration thread
  116. 1991 Standard/Manual Honda Civic Hatchback - Wont Stutter
  117. 1990 Honda Civic - Problems after fuel pump replacement
  118. 86 CRX Cali Emissions - Gear Ratio Adjust???
  119. 91 EF sedan project
  120. D16y5 Gen 1 Crx hf
  121. CVCC INTAKE SYSTEM
  122. JDM Honda BEAT
  123. Wierd high idle
  124. A Second Gen. Honda Civic as my First Car?
  125. German S-Car Meeting 2016
  126. 1985 CRX Si - Mugen theme
  127. 1987 Honda Accord Hatchback Timing Belt Question
  128. 87 CRX Si - Vacuum Leak?
  129. 1986 crx d16a1 swap
  130. WTB Vintage parts
  131. D16a1 swap
  132. 1980 Accord LX
  133. 89 Accord LXI coupe upholstery
  134. 2nd gen wagon crv??
  135. Gen1 Civic Question
  136. 68 Honda S800 Coupe
  137. Video of Z,N and S series cars in Portugal
  138. Lovely torsion bar questions
  139. Buying a 1983 Accord
  140. 2nd gen civic B18C converting to RWD
  141. 85 CRX with EG hubs, possible?
  142. 1983 Honda Civic 1500 s
  143. 84 CRX transmission locked
  144. Torsion bar removal
  145. Timing belt
  146. Opinions next honda/acura
  147. 1986 JDM honda acty
  148. 1985 honda city build
  149. 1990 ef hatch w d16y7
  150. 86 crx sway bar
  151. #HondaSerialOne N600-1000001
  152. 1st gen crx
  153. 87 CRX dx
  154. 1986 crx
  155. Need New Auxiliary Float for 1985 CRX HF
  156. 1986 crx
  157. 1975 Civic wheels
  158. Wire goes where?
  159. 84 crx wire?
  160. 81 Civic Hatch Removal
  161. S600 restoration in South France
  162. 1985 CRX Si - Mugen
  163. 81 Civic Wheel Upgrade
  164. 84 head gasket
  165. 84 crx
  166. CHASSIS HELP
  167. 1987 hond accord lx
  168. 87 Honda Accord LXi
  169. 1988 Honda Accord LX Sedan
  170. What To Do??? '81 Civic Hatch...
  171. FS 1990 Honda City Mugen 2 door hatch - need idea on price
  172. <87 CRX to 85 Civic
  173. Hello! Need exhaust manifold for EB3 1200
  174. 89 Honda Accord lxi overheating
  175. 3bbl Keihin repair/rebuild/adjust
  176. 1972 Honda 600 coupe
  177. 1979 Honda Civic 1200 tape dack needed
  178. 1987 honda crx si swap
  179. 85 accord
  180. Emission Parts needed for my 81 accord
  181. Hey Guys, I want to replace my Carburetor.
  182. 1980 Accord Ignition Issues
  183. 1980 Civic 1500GL Burning Coolant
  184. 89 honda accord
  185. tailgate latch
  186. 87 crx si questions
  187. Unknown part found. PLEASE HELP
  188. Need help with specs
  189. Rod bearing? bad valve? timing?
  190. passport gauge question
  191. 3rd gen civic b18 swap need help !!
  192. 81 accord hatchback smog issues
  193. S-Car Meeting in Germany 2015
  194. Honda 600 on steroids at The Concours d'LeMons
  195. '83 Honda Civic fuel pump not getting power
  196. 1983 Civic Engine/Tranny Swap
  197. Transmisión Issues
  198. 1988 Honda Accord Lx proportioning valve
  199. 1983 Honda Accord will not start.
  200. Honda S 600 Fastback Coupe 1965 Restoration
  201. 1965 Honda S 600
  202. 1986 CRX - Here we go.
  203. Torsion Bars
  204. Possible Group Buy for 1stgen Civic Hatch Glass Seal
  205. 1st gen civic cvcc B18c1 turbo RYR Build
  206. 85 CRX Si 1.5 & tranny into an 88 Civic SE?
  207. "The Old School Reunion" Vintage Import Car Show Seattle, WA June 7th
  208. Check out this beauty! '79 Civic up for auction...
  209. 1984 honda civic wagovan
  210. 1987 honda accord help
  211. I need parts
  212. "Christine the evil 84 crx build"
  213. '95 CRX Engine Swap?
  214. 83-87 CRX fog light brackets and switch question-
  215. 1984 honda crx problem
  216. negative camber fix???
  217. 1985 Accord - Need Part / Help Finding
  218. 89 honda accord lx Main relay location
  219. 85 civic questions
  220. Hello from a new member
  221. 1986 Accord CA5 project !
  222. Weber adapter plate question...
  223. 1981 accord sedan, save it?
  224. 1982 civic swap. help!
  225. '88 Honda Accord Failing smog with high NOX
  226. help I broke my Crankshaft pulley and can't find a new one. '87 civic
  227. 1987 CRX aftermarket or interchangeable options??
  228. '88 Honda Accord LXI steering wheel turns all the way over by itself upon start!??!
  229. Second Gen Preludes Swaps?
  230. Rear Springs
  231. 1987 Honda Civic 1.5L Timing Retarded
  232. 1983 Civic Wagovan 5speed
  233. Honda S800 F20c
  234. 1987 crx dx idle issues
  235. Honda service manuals
  236. My 1989 Honda CiTy CR-i
  237. Little N600 restoration...
  238. 85 crx si no reverse
  239. 85 Civic Almost starts
  240. 84 Honda Crx DX Climate Control Issue
  241. 1989 honda accord 2.0L FI not charging battery
  242. 87 honda civic si
  243. First Gen Honda Prelude SN 1981
  244. 1980 Civic 1500 Vapor lock???
  245. RHD S600 - not used for 4 years
  246. Honda TN360 restoration
  247. Tail Lights
  248. 86 crx EW3/4
  249. newbie needs advice
  250. '87 Honda crx - newbie needs educated
