PDA
View Full Version : Classic Hondas
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. "PIC'S OF MY PROJECT 1989 ACCORD COUPE"
  2. '81 Prelude convertible
  3. 71 Honda N600 FULL RESTORATION!!!
  4. How do you pull the door panel + window wipe
  5. EF B20 Wont Crank Over - Injectors no Power
  6. What is the cheapest way to go for a grinding tranny?
  7. carburetor gasket no longer available. What to do?
  8. 1970 Honda N600 Swap Options? Build thread
  9. I NEED HELP WITH THE TPS
  10. 1986 CRX Si starting problems, please help.
  11. 82 Honda Accord 46KMS original Paint decision Need opinion
  12. 86' Civic 4WD Wagon
  13. 77 Civic trailer build... Many Pics
  14. 88 Hatch w/ 1st gen b16. HELP NEEDED!
  15. 1986 honda civic radio wiring
  16. Pulling out the Starter on an 87 CRX Si
  17. Possible Purchase: 1987 Civic Wagon 4WD Mint
  18. Carbs on a newer non-carb motor?
  19. Voltmeter ideas for 86 civic
  20. 91 dx Motor into an 87 Si
  21. D16 into 78 CVCC
  22. 85 AWD civic wagon built
  23. Need Advice on 1984 Accord Idle/Carb issue
  24. Fuel pouring out of left sideskirt!!!! Ahh!
  25. How the heck do u turn the clutch adjustment nut?
  26. Seatbelts wont lock during suddent stop.
  27. Adjusting the clutch to ensure clutch disengagement.
  28. 1986 civic si very rough
  29. swaping gauge cluster w/ out tach for one with
  30. 1986 honda civic si fuel problem
  31. 86-89 Accord and 88-91 Prelude Shifter
  32. EK1 82 Civic slow build.
  33. 78 Civic 4x100 conversion
  34. 1977 Honda Civic CVCC Valve cover done in Wrinkle Black
  35. whats a good color for the classic????
  36. 1986 CRX stalling when cold
  37. New in the forum
  38. Cup holders
  39. Civic Cranking
  40. Best way to check for vac leaks?
  41. Stereo install
  42. 1986 Honda Civic DX 165k miles Engine Rebuild & more (LOTS OF PICS)
  43. Front lip & Spoiler
  44. Suspension of EF on 87 Civic (AH53)
  45. Heater Blower
  46. Where to buy an IAC
  47. Cheap wiper arm fix
  48. 1987 crx engine swap
  49. 1987 crx idle issues
  50. need help on a 85 Accord
  51. 86 CRX Sunroof Motor
  52. Hey everyone, '84 civic
  53. 87 Civic 1300 1.3L.. interface or non-interface
  54. What is this front suspension part? Pictures inside. 1986 CRX-Si
  55. !986 Civic GL Front End Suspension Rebuild.
  56. Turbo, mid-engine Honda N600 racer for Grassroots Challenge
  57. NEED HELP PLZ!!!
  58. Any help with my Civic SI 87?
  59. Headsup: Canadian Honda S600 for sale
  60. Igniter keeps going bad!!
  61. My civic Si 87
  62. Possible Swap? Need Advice
  63. ****what kind of ITB i can use on my 81 civic wagon?????*******
  64. 83 Civic 1300 distributor oil leak
  65. 1989 Accord LXi - what's it worth?
  66. 1987 Civic Wagon for $1,200... Worth it?
  67. Radiator fan not working
  68. 1990 Honda Civic DX Tranmission Problem
  69. Keihin 3 bbl CVCC carb parts 83 Civic 1300
  70. 1977 CVCC civic I just picked up
  71. 85 Honda CRX Nose Panel Install Question
  72. 85 CRX front wheel hub...
  73. Help with a cvcc I can't get to start!!!
  74. I need help with a 1990 civic
  75. Wheel Fitment for 81 Civic
  76. Looking for the previous owner of a 1982 Tan CVCC in Hookset NH area junkyard
  77. 88 honda accord lx intake?
  78. Need help with a misfire
  79. First car 1991 civic hatch - Opinons
  80. 1987 CRX HF AC question
  81. 82 accord hatchback engine swap
  82. 1984 Honda Ballade
  83. Quick question
  84. 85 accord FI advance timing
  85. Wanna do and engine swap
  86. Got some new shoes and lowered it a lil bit....
  87. Couple of questions...'84 Civic 1300
  88. Power Window Issue in 1989 Accord LX...
  89. 1987 accord lxi 2.0l 5spd. idk what this is.
  90. need help asap!!!!!!!!!!!!!!
  91. 1989 Civic A/C
  92. Can anyone help me?! CRX oxygen sensor
  93. 1980 Civic resurrection question
  94. odometer, and trip don't work
  95. 1981 Accord LX keeps popping same fuse
  96. '84, 1300 Civic w/ high idle
  97. just got my ca5
  98. ** Classic wood stering wheel ? Honda-Tech help me identify !!!!
  99. rebuild (D16Z6)
  100. Starter sometimes keeps spinning once car starts (and other starting issues)
  101. Looking for a vintage Honda shop in Southern California
  102. 87 CRX Steering Wheel (interchangeable)
  103. Big Mikes 1987 CRX Build/Resto thread
  104. 1987 accord hatch trans leak
  105. 86 Accord water leak.
  106. 86 civic running rich! -__-
  107. Stuck bolt in suspension fork?
  108. 81 Civic Turn Signals
  109. Transmission help for my 1982 Civic 1300
  110. Thermo Vacuum Valve?
  111. Newby With A 1980 Honda Accord
  112. 87 lxi hatch accord with 89 a20a3 head troubles help!!
  113. Honda EB2 Racing Engine
  114. Picking up an 85 Hatch
  115. My 1979 civic cvcc
  116. Pics S-Meeting in Germany
  117. '87 Honda Civic Si Won't Start!!
  118. Anyone good with seat brackets?
  119. build spec for 86 civic
  120. 84 GL Acceleration Issues
  121. rack and pineon????
  122. Cooling fans running non-stop...
  123. 82 Civic Wagon Problems
  124. i just got a 1998 honda hatchback
  125. I have a big light problem can someone please help me!
  126. 87 CRX help with gauge install(searched already)
  127. ep3#2 help me and ill help u
  128. How do you change front marker bulb in 86 accord?
  129. honda civic 82 - fuel issue
  130. 87 civic wagon
  131. Opinions on emission controls removal 83 Civic
  132. wiring harness help
  133. Anyone know where to get O/S Civic 1300 pistons?
  134. 1987 CRX o2 sensor
  135. 87' Honda CRX SI Questions
  136. Thought I'd throw up pics of my other Hondas...
  137. 1984 Honda City Turbo CA Registration
  138. So I went down the road to the local track.....
  139. Civic lx 89 d15b2 1.5 stalled while slowind down wont start again, help needed
  140. 88 accord lxi engine
  141. '88 Accord Mystery
  142. Just bought an 86 crx
  143. Just bought a 1988 Accord DX.
  144. Need Help Finding Original Owner or Paperwork
  145. how to properly check auto-tranny fluid level?
  146. 1986 Honda Civic, High RPM Idle, Stuttering Up Hills
  147. 88 Honda Accord LXi - starting problems
  148. JULY 4TH!!!! Atlanta's Old School Japanese Car Meet...
  149. '83 Accord overheating issue
  150. Engine Decisions for my 82 Civic
  151. Stalling/ stumbling intermittent problem with my Accord
  152. 86 CRX HF
  153. Charging problems 83 Civic 1300
  154. oiling problems
  155. seats
  156. crxguy's 1984 CRX restoration/fixing thread. (56k warning)
  157. 86 Accord LXi idle issues
  158. My car at Import Alliance 2011 - Atlanta, GA
  159. New here...
  160. 1986 crx cylinder head help
  161. 1989 honda accord lx intermittant problem
  162. 87 CRX dx (lots of pics)
  163. 87 CRX idle issue
  164. Need help on the 1983 Honda Accord LX
  165. 1987 CRX Si Ignition problem??
  166. '81 Civic Alternator Wiring Burning Up, Where Do They Route To?
  167. What auto tranny fluid to use in 1st gen crx?
  168. 1984 accord having trouble starting
  169. How much compression should a 84 Accord LX have?
  170. head bolt problem
  171. beginner needs help
  172. 1986 Honda CRX Weather Strip Needed
  173. 1986 crx hf intake
  174. IACV location?
  175. Super Honda Noob (1st gen CRX content)
  176. 87 civic problems.
  177. Please help.
  178. Old honda head wants to find EF9
  179. 93 eg hatch....need some paint !!!
  180. Good site for JDM, EDM or CDM part #'s?
  181. New to forum
  182. crx hood
  183. crx distributor
  184. Need help 87 CRX two problems. And a Question.
  185. 1986 CRseX Interior Value $$
  186. 1986 CRX DX ignition question
  187. 1986 crx
  188. B20B Swap Info???
  189. Turbo 1981 Accord
  190. 1987 CRX SE?
  191. 1986 crx hf
  192. 85 Honda Accord help!!
  193. 88 Accord LXI problems
  194. #2 cylinder injector not shooting. ECU or Wire?
  195. 1987 civic that will not charge
  196. Got the front/rear bumpers put on...
  197. 89 Honda not starting
  198. 1985 HF Running Lean and Hard/stalling/stumbling cold starts
  199. I need help with my 88 Accord LX
  200. 86 civic hatch fuel pump?
  201. Bought an 82 civic and would like some help
  202. Honda carb cleaning kit 88 Honda Accord LX
  203. 1987 Civic CRX HEAD Removed (FRESH PICS CLEAN HEAD)
  204. 86 civic suspension question...
  205. 1987 CRX Blown head gasket, Which engine do i have??
  206. Engine swap on 87 CRX
  207. DPFI on an 84 crx non-SOHC block
  208. My -85 HB Civic fixing thread *with photos*
  209. G1 DA1 Swaps
  210. 84 honda civic not starting
  211. POST EM OLDSCHOOLS
  212. Honda S800 - Project 50
  213. NOS Honda Parts, places to look at?
  214. 83 Civic 1300 4 speed to 5 speed conversion
  215. My '79 CVCC
  216. 87 crx si- loose steering after new tie rods?
  217. Car runs after shut off.
  218. 84 crx carb problems
  219. Interested in selling/trading my 83 Accord LX Hatchback, but have some questions...
  220. Might be getting an 85 CRX...
  221. 82-83 Accord/Prelude Dual Side Draft Intake
  222. 92 accord climate controls
  223. 1986 Honda Civic Si 1500 Clutch Problems?
  224. 1986 Honda Civic Si 1500 Clutch Problems?
  225. 1987 Civic Si Hatchback Dash Lights (LED Conversion)
  226. 1986 civic hatch build
  227. Need advise on what clutch to get for my 78 CVCC
  228. Real USDM MUGEN CR-X Si
  229. Failed for NOx again 86 civic carb
  230. 85 CRX HF won't idle after warm up
  231. Are 86-89 Accord gears and final drive compatable with 86-89 integra housings
  232. 86 civic O2 sensor
  233. Front suspension 86 civic question?
  234. Rear Struts for 1980 Honda Prelude
  235. 1987 accord dx
  236. What other Hondas/Acuras have common parts with Gen2 Prelude (1985-1987)?
  237. 1987 honda crx si engine swap?
  238. 1987 wagovan
  239. 1987 honda accord overdrive constant on & off help
  240. 1stGenCivic.org? WTF?
  241. Who has pics of there classic honda with rare/hard to find parts???
  242. 1981 Civic 1500 Ignition Wires location?
  243. Rim choices for my 1982 civic
  244. s600 engine
  245. Strange water pump/alternator belt mishap
  246. 1987 Civic 1.5 SI bouncing RPMs on warmup?
  247. 87 accord.. Hesitates when warm.. runs great cold
  248. My 84 CRX
  249. 88-91 Civic 4wd
  250. 1989 Honda Accord lx Carb Fuel Pump Help
