View Full Version : Classic Hondas
Pages :
4]
11
12
- Just ask
- HELP PLEASE
- '89 Honda Accord
- Yellow Honda az600 coupe
- 86 CRX no power to fuel pump???
- 1977 Civic Wagon CVCC Valve Adjustment
- Tranmission question
- 87 CRX SI issues
- 86 Honda Accord - A few questions
- 1986 crx rust/other issues
- few questions about a 79 accord
- Potential Newbie here
- Civic 82
- Bent Valves!
- 2nd Gen prelude Choke issues
- 93 honda del sol si b18c type r start up problems, some one please help me out
- 93 eg hatch with b18b1
- Help! 89 Accord Shift boot acquisition
- I Want To Lower My 1986 Civic Si From The Rear.
- 84 CRX bearings
- CRX first gen
- Graf's arabian '87 Prelude 2.0Si
- Graf's '87 Civic aka. "Browntop-Hatch"
- 1982-85? clock HONDA ACCORD
- Was able to grab these...
- S500 - Two Owner.
- 86 crx si idle issues
- Went ahead and made this happen...
- 84 CRX stabilizer link
- 87 Honda Cvic 3DR Si Hatchback rr emblems
- 88 wagon help
- What would cause ignition timing to be off a TON? (14-degrees retarded)
- Back in a Honda. 87 CRX Si with a cool story (check it)
- Carb Question
- 1987 Honda Accord LX battery draining
- Windshield/Hatch Window Trim...
- might buy a 1986 accord
- 90 honda accord
- 84 Wagovan
- What did these old school enkeis come off of?
- S800 Crankshaft
- 1986 Honda Civic Wont start :( help needed
- Fuel tank sender unit
- Help! No spark!
- 2 barrel with a cvcc motor?
- 88 accord head
- prelude motor swap?
- have 79cvcc want earlier motor
- DeVac done! carb build and cosmetics next
- 2 barrel vs 3 barrel cvcc
- devacing an 87 civic
- ecu issues need some help
- thermostat housing question
- which one is the best?
- 1988 accord what would be the reason for oil in my air filter
- 83 Honda Accord LX swap?
- 1985 honda Civic some parts help needed.
- Question to all b-series guys: Which axles for 87 civic?
- 79 Civic - Worth it?
- 1987 Civic Hatchback Headlight Switch Mod?
- Picked up a 1979 Civic CVCC the other day
- 1985 ACCORD - HELP!
- 87 honda crx hf ideal prob
- EK1 Vaccum line simplify
- 82 accord ek1 wont turn off
- New (to me) 3g Prelude Leaking Coolant
- 3G Civics, what to look for?
- Honda N 600 Sedan Canoe edition
- 83 Acccord Keihin carburetor
- 86 civic carb woes
- New 3g Civic owner
- 1987 Civic Si starting woes
- Wagovan Dual Carb?????.... Need some advise...
- Lets show an EC3 some love?
- Should I sell or should I build?! 71 civic
- timing belt keeps slipping (im new and female hopefully this is posted in the right)
- Info/Question on 87 Civic Si Hatch
- 1987 accord lxi idle problems.
- 83 Civic engine swap possibilities
- 1989 Honda Accord ECU Location.
- The Blue Coupe
- 86 Honda Accord Oil leaking from oil filter mount.
- Pics Honda-Classics-Meeting Germany
- 1976 Honda Accord Restomod Project
- 1986 Civic Si Hatch
- '86 Honda Accord needs to be fixed up
- 1983 Accord LX
- any second gen 'lude owners?
- ANOTHER GREAT ADDITION TO OUR HONDA FAMILY- N600
- 1983 CVCC Accord help!
- 84 honda civic hatch
- old school cvcc
- non cvcc head that fits '83 EM1
- N600 Autoblog Article - a must read/see
- need wire diagram pinout - 79 accord hatch
- 1979 Accord Project: Bondo Mobile
- Where is Honda City forum?
- Just got a 1966 SM600
- Distributor for '89 Accord LXi KA5MT
- vacuum advance/ retard mechanism test??
- 1983 Honda Accord Hatchback need help!
- Sleeved h2b turbo swap into 87 crx build....
- i have a b18a1 with a programable chi and i have crome
- Help looking for an S600/800...
- 1986 Honda Accord LX-i Dashboard Lights aren't Working
- 86 carb civic almost stalls after the first startup
- 86 Accord LX-i Starting Issues
- 80 Accord Hatch, power failure
- ET2 side draft carbs
- 1989 accord (carb)
- My collection of classic honda videos
- '89 Accord LXi needs new A pipe
- Tutorial: Obd1 Main Harness Conversion For 86 Hatch
- '88 Accord - Fuel Issue?
- Bike Engine Honda AN 600 build
- engine transplant, how do you do it?
- heres my old girl (76civic)
- 86 CRX 1st gen b18c1 swap overheating
- 1982 Accord NOX high help CA
- 1987 CRX HF A/C question
- Browntop ZC Obd0 to Obd1?
- My 86 Civic Si camshaft broke!
- 1971 Honda AN600 (Amarillo Texas) for sale
- 87 Honda Accord F20B Swap (in progress)
- I have a 84 honda hatchback
- AC for SB1
- Charging Issue
- Changed head gasket on my Shuttle - wont run properly now...
- schematics for 81 civic??
- 77 Civic engine blowup
- 1983 Honda Accord carburetor floats
- Fan switch,temp switch??
- RSX 2006 CLUSTER SWAP ON CIVIC 84-87 HB
- 1969 S800M Coupe.
- paint code for Blue CRX
- 86 Honda civic
- 1986 LXi 2.0 No Start
- 1989 Honda Accord Fast Idle
- 1987 CRX Timing issues
- 1986 civic Si pgmfi issue??
- 98 Civic alternator in an 86 accord DX
- wheel size for my 82 civic?
- 1987 accord LXi possible engine swap
- Old Hondas at Crystal Palace, London , England
- New Facebook Page "Honda Roots", check it out!
- 1982 Civic wagon Crank Pulley
- A New Life for my 86 Accord DX
- 1983 Honda Accord timing belt
- 81 Civic retrofit
- 1986 Accord trailing arm removal question
- 87 Honda CRX DX Will Start But Won't Stay Running
- 83 Honda Accord H22A Swap? Possible?
- Carburetor problems
- HIGH IDLE PGM-FI LIGHT ON PLEASE HELP
- just picked up a 1972 n600
- n600 intake
- 87 CRX HF engine just quits when driving
- 1989 Accord LXi will not start
- Flywheel bolts tough! Seals etc.?
- 1989 Honda Accord LXI stalls while driving
- 82 Civic Wagon: Brake Upgrade
- Oil pan gasket change (86 CRX Si)
- How not to use your honda
- Tims 71 N600 build thread (image heavy)
- Hey all, looking into Civic's as a first car. I need help!
- Help- Headlight motor malfunction
- 85 civic motor fitments
- Shaun's 86 Si
- first gen accord b16 swap
- Saw this at a car show
- 1987 Honda Accord LX-i - Oregon
- pic request AF civic hb
- 1987 Honda Accord LX-i Hatch
- '86 CRX HF, woot woot
- 93 accord trans prob any help appreciated
- Where to buy a S600 or S800?
- 83 Accord Fuel pump
- My 87 Accord Hatch Project
- Z600 Coupe
- 88 Accord - Gear selector issues - please help guys, this might be super simple!
- UNKNOWN POWER DRAW
- GAS TANK OVER FLOW
- 1986 honda civic si 1500 1.5 ecu
- 1982 Civic Wagovan
- 81 civic head gasket problem
- 1980 honda VIN help...
- 1985 crx si needs head options?
- /--86 Civic HELP!--\
- so confused
- 83civic k24 swap
- 1989 Honda Accord LX build
- what will fit as a cat back?
- 1987 Honda Wagovan help
- Need more Power 86 Civic Si
- Does other 2nd gen civic tail lights fit the 81 hatch?
- Help preserve old cars in California
- Buying a 1976 Accord CVCC
- 80-82 Accord gauge cluster
- CRX Si electrical problem
- Owners Manual for Almost Classic '89 Accord LX
- 1982 Honda CiVic GL, The start of an excellent daily driver.
- Convert 86-87 Vac. Advance PG7 ECU from auto to 5 speed?
- 1982 civic sedan 28k
- To Sell or not to Sell??? 1988 Honda Accord
- Need help with my 85 accord.
- New 1986 Accord DX - Wont start. HELP!!!
- 87 Honda Accord Radiator hose problem
- DOHC ZC idling up and down?
- 85 Accord, B-series swap?
- 1983 Civic 1500s
- 1st-Gen CRX Rims - Parts? Centrecaps?
- 85 CRX B16A Honda Tuning Article
- cracked intake boot causes rough idle after going uphill?
- My 89 CA6!
- Distributor for 1986 CRX
- 80 civic hatch
- 1987 CRX Si aptly named "Pugly"
- CB125T 1977 should I sell?
- First generation CRX fenders?
- E-Brake light stuck on?
- 1983 Honda Accord not starting?
- New to FWD, new to Honda, new-to-me 1987 Civic 4dr
- DA3,Av1 integra
- new member
- 89 honda accord help!!!!!
- 1972 Honda N600 sells at Mecum Auto Auctions for $16,500
- ECU Got Soaked - What now?
- Transmission Leak
- 1984 AH civic. blown the head gasket four times!
- 1986 civic Si idle problems
- Help me with accord 1983
- 87 CRX SI B18A1 Build
- B18 small mods or just leave it alone?
- Diamond Racing Steelies on 2nd gen Civic?
- 86 crx si cable clutch issue
- 1975 4 door eb1 Hatch - engine spec drama
- Help with parts for 86 civic 4door
- Another 71 n600
- 86 si hard start and bad mpg
- 1965 SM-600 pics
- 87 crx DX to HF conversion questions
- S600 help needed
- Honda N600-help wanted!
- My 1981 Accord Pictures Thread
- Wooden shift knob ??
- 1986 honda civic si speaker locations
- K24 powered 1972 AZ600 Coupe by Meris Motorsports
- 1977 CVCC Alternator
- Saw this 600 in Albuquerque
- 84 civic ev1 head gasket
