Classic Hondas All Pre-1988 Hondas.
in need of some advice
Old Apr 2, 2014 | 09:36 PM
AndresaFranck's Avatar
Default in need of some advice
Hello I have a 1987 Honda Accord DX model four doors, and I am thinking of doing and EFI swap on it and as well as a transmission changed over from an automatic to a five speed, I wanna boost this car an make it a sleeper and see what all is out there for it, I also want to change the rear drum to disc need alt the input i can get
Old Apr 5, 2014 | 07:35 AM
CRXR's Avatar
Default Re: in need of some advice
Id go with a b series swap n boost it, but there is just so many options that i can sit here all day telling what to get, just do a little reasearch on engine setups to see what fits you budget n power goals
Old Apr 7, 2014 | 05:16 AM
ej1995's Avatar
it's not as simple as it may sound. you cant just "EFI swap" mainly because you'd have to change everything from the fuel tank and lines all the way up to the intake manifold, change the wiring, ecm, and the list goes on.
also, manual transmission swap is relatively easy if you have a parts car to pull from.
rear disc brakes can probably be had, but its not a common swap so you're probably going to be hunting forever trying to figure out what pieces you can put together from a newer civic/accord/integra to make it work.
honestly, its not going to be that fast regardless of what you do to it, so your best bet is just to do all the stuff it needs done maintenance wise, put a decent suspension setup on it, and change it over to a weber carburetor, then you get a decent perfomance gain and its do-able.
Old Apr 7, 2014 | 06:26 PM
thanks all, but I found a donor car its from a 1995 honda civic its got a 1.6L vtec, the owner of car only wants $300 i dunno if it would be the effort in put that motor n the accord
Old Apr 9, 2014 | 01:04 PM
ej1995's Avatar
you wouldnt gain anything really. plus by the time you changed EVERYTHING over, you'll have a ton of money in something that isnt worth anything. i'm trying not to be too negative on this, but the practicality of this build goes out the window by converting to fuel injection and changing an engine to a series that is not native.
Nebunaut
Dec 20, 2016 11:41 PM
v6ricerocket617
Jul 11, 2014 09:03 PM
jmurphy
58
Mar 25, 2011 06:22 AM
deem
Feb 14, 2008 12:14 PM
Slackwise
12
Jul 9, 2005 08:20 PM
