PDA
View Full Version : Classic Hondas
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12
  1. Tail light bulb socket swap on 86 civic
  2. Honda Z Small SUV Parts Help
  3. Bay Area Shop Willing to Work on 2nd Gen
  4. 1985 Timing Belt Swap. Video?
  5. 86 Si swap into 86 AWD Wagovan, easy or skip it?
  6. Looking for help identifying the carburetor on a 1985 civic.
  7. !983 Accord Idle issues
  8. 1980 clicking fuel pump
  9. Where is Thermovalve B located?
  10. 1987 Honda Civic Wagovan 1.5L (not AWD) idle and staying on when starting problem
  11. 5 lug conversion 2000 civic
  12. Reviving AC?
  13. 1984 Civic CRX 1.5L Project
  14. Attempting to install a distributor and failing
  15. Accord CB3 frontlip
  16. Auto 83 civic d16z6 possible?
  17. Carb Insulator gasket, 86 DX
  18. Speed activated auto door locks? 1989 Accord
  19. Lower Control Arm Bushing Question '87 CRX
  20. 1978 Honda Accord fuel issue.
  21. Random cylinder misfire
  22. AC condenser suggested replacement for 86 DX
  23. 85 civic 4-door manual transmission (base) needs new engine
  24. 87 Accord Seat/door Beeps and not engaging
  25. B18b2 swap an build
  26. Thermostat prefered brand help
  27. HELP!! - 1987 CRX Si rubber air intake hose
  28. Dpfi to mpfi conversion
  29. Tires for a Honda Accord 93’
  30. 1975 Honda civic
  31. 1987 Accord Hatchback LXi - long run time on fans
  32. Oil for 1985 Accord
  33. Engine swap for carbureted 1986 crx dx
  34. Radiator Fan On with Ignition
  35. EK3 Civic transmission leak
  36. Fitting an EK4 (VTi) rear muffler on a EK3 (LS)
  37. Clean Fuel Injectors on 1987 Honda Accord LXi
  38. D16z2
  39. 1989 Coupe - No Start
  40. Desperately looking for a radiator for my 83 accord
  41. 1983 civic - how to pull the gas tank
  42. IACV/FIV possible final solution
  43. Crank time getting longer and the Smelling gas? 98 EK
  44. Ignition system problems 88' Accord DX
  45. 1984 civic sedan
  46. Tire Choices on an 87 LXI Hatch
  47. reputable restorer?
  48. 1986 Honda accord LXI PGM FI light
  49. 1981 Honda Accord, needs gas tank
  50. F22b1 looking for stage 2 bisimoto cam or just aftermarket
  51. First 70s Civic CVCC
  52. How do i make my 89 accord wink ??
  53. Dashboard symbols- (!) and BREAK
  54. 1986 Civic Shuttle
  55. Buying my first 70’s Civic
  56. Anyone know where the 2nd gen civic motor is stamped?
  57. 1987 Honda Civic Si Turn Signal Switch Broken
  58. 1981 Accord suspension
  59. Looking for 86' civic si dash light wiring diagram
  60. Water pooling on driver's floor
  61. Getting a rebuilt title pls help
  62. 1989 Legend Coupe - mechanic needed
  63. 1983 accord dies when rpms go below 1k & if put into gear
  64. 1987 honda accord LX window only goes up
  65. Good brand of alternator? 1987 Civic DX hatchback
  66. Honda Civic ‘78 getting into gear
  67. WTB - LH head light cover/protector
  68. Need hlp with my 1988 acura integra
  69. 1980 civic transmissions
  70. 1982 Honda Accord: Rebuilt Carb now idles at 3k-5k
  71. 1991 Civic DX Special Edition
  72. 1989 acura integra temp gauge constantly on hot
  73. Custom axels for a 1980 Honda
  74. 1983 Accord LX rear brake pads?
  75. 1980 Honda civic swap
  76. 92 civic D16Z6 troubles
  77. 1983 City Turbo Fuel Filter
  78. 1987 Wagovan coilovers?
  79. TNCG Episode 29 | Honda Acty Torsion Bar Bushing Fix for Steering Death Wobble
  80. 99 civic was never tuned and ran lean
  81. 1983 Honda Coil Issue
  82. 1990 Honda Accord oil pressure
  83. 78 Accord door latches
  84. 78 Accord CVCC carburetor swap
  85. 1st Gen new buyer question
  86. 91 EE2 wagon making scraping sound
  87. Window regulator issues
  88. 1981 Honda Civic D swap
  89. Options for 77 CVCC Civic Carb
  90. 1980 Accord LX Hatchback Hondamatic front wheel bearing
  91. Civic VX Door. Molding?
  92. 91 Honda Civic Dx
  93. 1983 Civic engine failure
  94. I'm going on an Adventure !
  95. Flywheel/ring gear needed for 1980 Honda Accord
  96. '73-'79 Civic 1200 exhaust header (aftermarket)
  97. '77 Civic 1200 water valve
  98. 1980 Honda Accord 1.6 EL engine timing belt
  99. Honda civic 2002 ex 5 speed starting problem
  100. '83 Civic Carb Swap?
  101. 1985 CRX LSD vibrations?
  102. 1987 accord d15b1 possible?
  103. 87 Civic Motor Mount Question
  104. Civic 1981 oil pump
  105. Honda T500 mini truck
  106. Fast Idle on carb 85 civic -fixed- for now
  107. clicking on passenger side
  108. Honda "S" Mechanics
  109. 1978 Honda Civic Hondamatic Brake Line Size
  110. SOS Headlight Retaining Plastic
  111. Problem with fuel system/fuel pump.
  112. suspension advice
  113. 85 civic, Defogger wire cut off and no brake lights
  114. So You Bought a 1973-1979 Civic?
  115. Honda City Turbo 2 1983
  116. Honda n600 1968 Rebuild
  117. 2015 Honda Jazz started to give a warning but i dont know know what it wanted to warn
  118. Ecu help
  119. Honda Civic MK1 1978 Radio/audio upgrade
  120. 1973-1979 Civic SCCA Pictures
  121. 75 CVCC Engine number
  122. 86 CRX Si: can wrong oil pan cause oil in PCV?
  123. Help! 1989 Accord LXi
  124. Will a18a transmission bolt onto a20a
  125. Fast Idle Valve
  126. roof repair support
  127. Sending unit
  128. [1987 CRX] Help!! I can't get my front bumper back on...
  129. 1983 Honda Accord 4cyl Zero HP help
  130. 1978 Civic GTC Rebuild
  131. 87 Civic Si Idle Adjustment
  132. '82 Prelude CVCC issues
  133. Fuel Sender
  134. 1980 cvcc B16a swap drag car
  135. Clocking a strut with no bearings
  136. 1987 CRX Brake Proportioning Valve Replacement
  137. Can't find Fuel Filter on 89 LXi FI
  138. My new 1983 Honda civic wagon
  139. **New Owner 1985 CRX**
  140. 100% stock, rust free, 1986 Civic Si Video Series
  141. Odd fuel level sender 5 bolt pattern
  142. 86 Civic Si, need some help
  143. 1973 Honda Civic 1200 brake calibers needed
  144. Thoughts on this 1979 Civic
  145. Head Bolts
  146. Performance parts
  147. New 71 n600 looking for a winsheild
  148. 89 accord missing throughout rpm range
  149. HONDA QA50 Valve Lifters?
  150. 1987 Accord LXi rough idel at stop lights
  151. 1984 Wagovan rear bearing
  152. 1988 Accord
  153. Engine swap on a 1985 fwd civic wagon with 5 speed.
  154. HONDA BEAT PP1 1991-1996. OIL CHANGE AND SUCH
  155. Does anybody ANYWHERE part out Accord 2s?
  156. 1981 Honda Accord issue
  157. First gen CRX factory spring rates?
  158. 1975 Honda Civic CVCC - In need of a new gas tank
  159. 1986 SB3 Civic 1500s D16A1 swap
  160. Body kits
  161. 5 lug conversion?
  162. Honda z600
  163. 82 Civic Brake Info/Service Manual Info
  164. 77 honda civic 1200 eb1 engine
  165. P28
  166. '87 Civic Hatch Parts- Where to look?
  167. What's it worth? 71 Honda 600 sedan
  168. 1974-1978 muffler question
  169. Trying to identify this part, 81 Civic
  170. 1986 Civic Hatchback SI fender same as 1985?
  171. 1986 Civic Si Fuel Issues
  172. Where is the resistor box on a 1987 crx si. I can not find it
  173. Old 75 CVCC rust bucket
  174. E series and d series transmissions
  175. 87 honda fuel pump
  176. 2.0 to 1.5 compatibility
  177. Help pls
  178. Ek hits cut off by itself
  179. 1982 Honda Civic Wagon Advice and Questions
  180. 1978 accord issues
  181. 1980 Accord Engine damage
  182. Ignition Coil 1st Gen Honda Accord
  183. New to the forum
  184. 84 crx carb rebuild pricing
  185. 1988 accord question
  186. 00 Civic Si GSR swap IDLE ISSUE
  187. 1981 Civic squealing
  188. Bad head gasket maybe?
  189. 1986 Honda Accord Lxi baro sensor location?????
  190. 1980 Civic 1500 Ignition Timing
  191. HELP 1989 A20A3 engine reassembly
  192. 1980-83 Civic Auto to Manual Trans Swap?
  193. WTB 1980-1983 Civic 2 door
  194. 1980 Accord flywheel Step depth????
  195. 86 Honda Civic DX No start
  196. honda fan switch 1983 civic 1.5 L
  197. 85 CRX questions
  198. THREE N600's!
  199. Honda S600 Build with Videos
  200. Honda Civic 3rd generation
  201. 1981 Accord Hatchback cvcc Won't Start
  202. Can't find carb mounting gaskets for 79 cvcc
  203. Help! How do you get automatic shift cable out of transaxle???!
  204. Honda SB16 Project
  205. Honda s800 coupe 1968
  206. Honda S600 handbrake cables
  207. Window regulator hardware
  208. buying a 1987 honda civic dx (what should I know?)
  209. 1978 Honda Civic 1200 1.2L
  210. Honda S1100?
  211. 1985 accord sei lowering
  212. No fuel to carburetor
  213. '87 Crx Si - Where to get in-tank fuel filter?
  214. Issue with steering wheel noise
  215. 1970 N600 ignition question
  216. Head bolts for ‘79 1.8
  217. 1983 Honda Civic Engine Rebuild Break-in/Smogging
  218. 87 accord manual transmission question
  219. 87 crx turn signals not working!?
  220. 1973 Honda Civic Dx 1500 Transmission Advice
  221. 1987 Honda Accord LX is this unsafe Subframe RUST
  222. HELP!! 1983 honda civic condenser
  223. Look what happened today.
  224. HELP! What is this honda civic 1983 1500 part?
  225. Door Panel Uphol. Quick Fix
  226. 1986 Honda Accord Restoration and Parts Questions.
  227. 86 accord fuel injected build potential?
  228. 1984 Civic 1500 possible head bolt over torque on first pass
  229. Motocompo commission
  230. 83' Civic with Mystery Bores
  231. 1994 Honda Civic with under 15,000 miles
  232. Headlight Bezel for 1983 Civic 1500DX
  233. 1983 Civic 1500 DX Hatch- Motor Oil Suggestions?
  234. 84 crx with issues
  235. Assistance identifying gaskets please
  236. HELP classic newbie, 82 prelude carb floods floats seem ok
  237. 3rd Gen 1986 Civic base 1.3 with vacuum and idling problems
  238. 87 Accord 2.0 (carb.) head and valve questions
  239. D16z6 starter problems
  240. D16z6 starter problems
  241. 1983 civic 1500cc head bolts
  242. 1979 Honda Civic hondamatic 2nd gear issue.
  243. 1980 First Gen Accord Build (Youtube)
  244. 87 crx si plastic body panel cracked
  245. Front Strut Mounts for 83 Civic
  246. 81 Civic Wagon
  247. Trouble restarting after running for a while 1988 Accord exi
  248. 1998 honda civic dx stock with a skipping problem
  249. Low idle/Engine Shutoff 88 Honda Accord
  250. B16A muffler choice help
