'86 crx si replacement tps
Any one have any ideas on a replacement TPS or replacemaent throttle body options or any other suggestions, once this is handled every thing will run smooth and then i can start modding. Idle is bobbing up and down seems typical for a bad tps. checked voltage .48 at closed 4.25 at full it does not progress smooth.
would prefer to avoid the junk yard if possable.
Re: '86 crx si replacement tps
86-87 Integra, Accord, and Prelude TPS might work, you will have to cut the end of the plug off your old one to install a new one. Otherwise I am sure Danny at NW Classic Honda (previous post) would be more than happy to hook you up.
Possible Throttle Position Sensor Solution For 85-87 Crx/civic Si - Swaps - Red Pepper Racing
hellraiser7492
05-26-2009 05:38 PM
hondastrtracr
13
06-24-2007 10:17 AM
